0 Replies Latest reply on Nov 5, 2010 11:03 AM by locollama
    IN operator in sqlite local database
    locollama
      New to the whole sql world, im building my first database air application.
      I have a database that i'm working with Asynchronously.
      I'm trying to get a sql result that gives me a list of all the entries (rows) that match a predefined list or array.
      I would like to use LIKE but that only returns to me one row in my database.
      I found the operator IN but i'm not getting the desired results
      with this following code
      i get multiple rows results.
      private function Add():void
                      var q:SQLStatement = new SQLStatement();
                      q.text = "SELECT * FROM testdb WHERE Symbol IN ('Apple', 'Orange', 'Cat');
                                     q.sqlConnection = conn;
                      q.addEventListener( SQLEvent.RESULT, Add2);
                      q.addEventListener( SQLErrorEvent.ERROR, queryError );
                      q.execute();
                  private function Add2( event:SQLEvent ):void
                      var r:SQLResult = SQLStatement(event.currentTarget).getResult();
                      dg.dataProvider = r.data;
      If i use the LIKE statement then the lettercase of the word doesnt matter but i get only one result in my Datagrid.
      If i try to use a parameter, my ouput is an empty grid.
      if i change to the testArray variable, i receive the same thing.
                public var testString:String = "Orange, Apple, CAT";
                public var testArray:Array = new Array("Orange","Apple", "CAT");
                      q.text = "SELECT * FROM testdb WHERE Symbol IN ?";
                      q.parameters[0] = testString;
                      q.execute();
      IS there a way to get the IN operator to work with a parameter calling an array or string?
      IS there a way to get multiple results from a LIKE operator?
      thanks for the help in advance
