3 Replies Latest reply on Nov 7, 2010 9:27 AM by pixlor
    Fireworks help
      Hi, I have this task where I have to use fireworks (I've always used Photoshop up until now) and I am in the process of familiarising myself with it however part of this task asks the following:
      "Save the end result of your image in the native file format for the application -- retaining edit-ability.
      Compress and export the image in a suitable file format in the highest visual quality available but also at the lowest file size."
      I never did this stuff with Photoshop but either way I know that the native file format is a .png and I'm guessing that the edit ability is on as a default (or not?) when you save it. I don't know how to "compress and export the image in a suitable file format in the highest visual quality available but also at the lowest file size." So any explanation, info or links would be appreciated!  Thanks!
        • 1. Re: Fireworks help
          pixlor Level 4
          The Fireworks .png format is an enhanced version of the standard .png format, to allow it to handle the vector shapes and other special data that Fireworks uses. If you save a .png from Fireworks, you get a Fireworks .png.
          When you want to create an image for use on the Web, you want to have a .gif, a .jpg, or a flattened .png (a standard, flattened bitmap one, not one of the enhanced FW ones with lots of extra data). These are the "suitable format" options. To do that, you want to export from FW. You can either use File>Export... or File>Image preview... to set up the parameters for the export. (You can set some parameters when you create a slice, too.) Personally, I like the Image preview... option.
          Create a new FW image, maybe with a couple of rectangles on it, and experiment with the options under File>Export... and File>Image preview... to see what's there and what you prefer.
          • 2. Re: Fireworks help
            Rfn_Nick_C Level 1
            Excuse the lateness of my reply but thank you! That pretty much answered it!
            • 3. Re: Fireworks help
              pixlor Level 4
              Yeah, nothing like being clear...
              As always, it's .jpg for photos and .gif or .png for line art. Oh, yes... Firework's PNG 32 is the same as Photoshop's PNG24 with transparency; FW's PNG24 does not have transparency; FW's PNG8 is an indexed 256-color palette (like GIF), except that it does support multiple semi-transparent values. See:
              The PNG8 format is very useful when you have a piece of line art with limited colors, where you want transparency, and you don't want to code for PNG32 functionality.
              If you do export to PNG8 or GIF, you might find that you don't get all the colors in your image. It's been this way for a long time. You can use Image Preview and manually add values to the palette with the eyedropper.
