Why does Contribute change the case of folder names? For example, folder names in Windows Explorer include "KMS," so a pathname might be Y:\KMS\folderX\file.html. But, when that file is referenced in a URL created in Contribute, the KMS is now lower case, for example: http://xyz/kms/folderX/file.html. This really is not a problem from a navigation point of view, but in a knowledge management system that spiders content this is a problem because the spider is case sensitive. And, if the same file has two different versions of the URL - one with UPPER case and another with lower case - it will spider it twice thinking it's two different files which yields two hits in the search results of the knowledge base.
I have seen no property setting in Contribute or the spider that modifies this property. Thoughts?
