4 Replies Latest reply on Nov 7, 2010 6:19 PM by unique_screenname_here
    Recursion with Pixel Bender?
    agsandrew7
      Dear PixelBender gurus,
      Is it possible to create recursive image processing in PB? In other words is it possible to feed generated output back into processing algorythm as a source within the same pbk file? I would appreciate some basic example or link to relevant reference source.
        • 1. Re: Recursion with Pixel Bender?
          unique_screenname_here Level 3
          No, it's not possible to feed the generated output back into the same incarnation of a filter. However, you could simulate recursion of a fixed depth by creating a linear chain of Pixel Bender kernels strung together in a Pixel Bender graph.
          • 2. Re: Recursion with Pixel Bender?
            agsandrew7 Level 1
            Can you provide very basic example of how such PB graph file would look
            like. Can such file be used in Photoshop as a single PB filter? I find that
            PB kit can generate solutions that are not usable due to the limitations of
            the target application. Thank you in advance.
            • 3. Re: Recursion with Pixel Bender?
              * ADOBE SYSTEMS INCORPORATED
              * Copyright (C) 2010 Adobe Systems Incorporated
              * All Rights Reserved.
              * NOTICE:  Adobe permits you to use, modify, and distribute this file in
              * accordance with the terms of the Adobe license agreement accompanying it.
              * If you have received this file from a source other than Adobe, then your
              * use, modification, or distribution of it requires the prior written
              * permission of Adobe.
              <graph name="BoxBlur3Iterations" xmlns="http://ns.adobe.com/PixelBenderGraph/1.0">
                  <metadata name="namespace" value="AIF" />
                  <metadata name="vendor"    value="Adobe Systems" />
                  <metadata name="version"   value="1" type="int" />
                  <parameter type="float" name="radius" >
                       <metadata name="defaultValue" type="float" value="5.0" />
                       <metadata name="minValue"     type="float" value="0.0" />
                       <metadata name="maxValue"     type="float" value="25.0" />
                  </parameter>
                  <!-- Image inputs and outputs of the graph -->
                  <inputImage  type="image4" name="src" />
                  <outputImage type="image4" name="dst" />
                  <!-- Embedded kernel -->
                  <kernel>
                      <![CDATA[
              <languageVersion: 1.0;>
              // basicBoxBlur: A simple example to demonstrate how to implement a 1
              //                iteration box blur.  The kernel demonstrates how to implement
              //                a convolution using for loops.
              kernel BasicBoxBlur
              <   namespace : "AIF";
                  vendor : "Adobe Systems";
                  version : 2;
                  description : "variable Radius Box Blur"; >
                  // A parameter that represents the radius of the blur in both the X and Y
                  // directions.
                  parameter float blurRadius
                      minValue:float(0.0);
                      maxValue:float(25.0);
                      defaultValue:float(5.0);
                  // A dependent value.  These are calculated in the evaluateDependents()
                  // function and save us from having to perform repetitive calculations
                  // for each pixel.
                  dependent int radiusAsInt;
                  // evaluateDependents(): Built-in function to do any pre-processing of the
                  //                       parameters.  Usage of this function helps avoid
                  //                       repeating any necessary instructions per pixel.
                  //                       In a filter as simple as this, the extra cycles
                  //                       are probably not necessary, but it serves as a
                  //                       good example.
                  void
                      // Convert the dimension into a integer value for use in the iteration
                      // over the kernel window.  All type conversions are required to be
                      // explicit.
                      radiusAsInt = int(ceil(blurRadius));
                  input image4 src;
                  output float4 dst;
              // Region functions are not available in Flash targets, so we only define
              // the functions if we are executing on a different backend.
              #if !AIF_FLASH_TARGET
                  // needed(): Indicates what area of the input is needed to fulfill the
                  //           requested output region.  In this case, we consider a
                  //           radius sized area of the input for each output pixel, so we
                  //           need to outset the area by one.
                  region needed(region outputRegion, imageRef inputRef)
                      float2 singlePixel = pixelSize(src);
                      return outset(outputRegion, float2(singlePixel.x * ceil(blurRadius), singlePixel.y * ceil(blurRadius)));
                  // changed(): Indicates what area of the output is affected by the
                  //            specified input.  In this case, we will blur out the image
                  //            by the size of the radius, so the output is the input outset by
                  //            one.
                  region changed(region inputRegion, imageRef inputRef)
                      return outset(inputRegion, float2(singlePixel.x * ceil(blurRadius), singlePixel.y * ceil(blurRadius)));
              #endif
                  // evaluatePixel(): The function of the filter that actually does the
                  //                  processing of the image.  This function is called once
                  //                  for each pixel of the output image.
                  void
                  evaluatePixel()
                      // Containers for both the accumulated color as well as the number of
                      // pixels touched.
                      float denominator = 0.0;
                      float4 colorAccumulator = float4(0.0, 0.0, 0.0, 0.0);
                      // Iterate through the kernel window, adding up the samples in
                      // that location.
                      for(int i = -radiusAsInt; i <= radiusAsInt; i++)
                          for(int j = -radiusAsInt; j <= radiusAsInt; j++)
                              colorAccumulator += sampleNearest(src,
                                  outCoord() + float2(float(i) * singlePixel.x, float(j) * singlePixel.y));
                              denominator++;
                      // calculate the resultant pixel value which is the accumulated color
                      // divided by the total number of pixels.
                      // In this case, the denominator is 9.
                      dst = colorAccumulator / denominator;
                  </kernel>
                  <!-- Instances of the nodes -->
                  <node id="boxblur1" name="BasicBoxBlur" namespace="AIF" vendor="Adobe Systems" version="2" >
                      <evaluateParameters>
                          <![CDATA[
                              void evaluateParameters()
                                  boxblur1::blurRadius = radius;
                      </evaluateParameters>
                  </node>
                  <node id="boxblur2" name="BasicBoxBlur" namespace="AIF" vendor="Adobe Systems" version="2" >
                          <![CDATA[
                                  boxblur2::blurRadius = radius;
                  </node>
                  <node id="boxblur3" name="BasicBoxBlur" namespace="AIF" vendor="Adobe Systems" version="2" >
                          <![CDATA[
                                  boxblur3::blurRadius = radius;
                  </node>
                  <!-- Connect the graph -->
                  <connect fromImage="src" toNode="boxblur1" toInput="src" />
                  <connect fromNode="boxblur1" fromOutput="dst" toNode="boxblur2" toInput="src" />
                  <connect fromNode="boxblur2" fromOutput="dst" toNode="boxblur3" toInput="src" />
                  <connect fromNode="boxblur3" fromOutput="dst" toImage="dst" />
              </graph>
              • 4. Re: Recursion with Pixel Bender?
                Flash only supports a subset of the Pixel Bender kernel language and it does not support the Pixel Bender graph language. The toolkit will communicate this information in Flash preview mode or in alll the preview modes (GPU, CPU, and Flash) if "Turn on Flash Player Warnings and Errors for All Targets" is enabled. Are you finding a case where this is not true?
