7 Replies Latest reply on Jul 18, 2007 10:31 AM by Catfish Tales
    From Robo5 to Robo6
      Hello. My boss has asked me if I think we should upgrade to Robo6, and I am not really sure. Looking at the top reasons to upgrade list, it seems Screen Captures ( I currently use SnagIT and they can be blurry after inserted into Robo), and user-defined variables might be helpful. A few questions:
      Do user-defined variables mean that if developers change the name of a product or field that you can search and replace all instances of the old name?
      Also, we are hiring another writer (both of us remote) and want to look into RoboSource Control. Do you suggest upgrading to Robo6 for this reason only?
      Are people running into a lot of problems when upgrading? I'm petrified of problems with our skin, template, links, etc. I went through a Robo conversion many years ago at a big company who had a technical person just for the TW group to fix those problems - but I am on my own here.
      Lastly, what was the release date of Robo6?
      Thanks very much for any help.
        • 1. Re: From Robo5 to Robo6
          Brian.Mccaffery Level 1
          Hello KayNay,
          Welcome to the Forums.
          Follow this link to a previous thread which may provide the answers to your questions.
          Hope this helps,
          • 2. Re: From Robo5 to Robo6
            RoboColum(n) Level 5
            Hi KayNay and welcome to the RH community. What I offer here are my own personal experiences of RH and may well differ from others. You can gain a lot of info that will help answer some of your questions by searching back through these forums.
            The user variables feature allow you to create a variable (e.g. Version) and add a value to it (e.g. 1.0). You add the variable to the text and when you compile RH substitutes the veriable for the value. If you change the variable value (e.g. ti 1.1) it will be used when you compile. In short the feature allows you to change values that appear multiple times in the help only once.
            As far as RoboSource Control is concerned, I'd look at other source control packages (e.g. SourceSafe) and would not upgrade purely for this feature. There are users of RH who use RoboSource Control. Whatever you use, it is wise to think about how you will use it.
            Skins, templates, etc have been around in RH terms for awhile and work fine. That is not to say you won't hit problems. Maybe you will but you'll find these forums an excellent resource to solve the. It is rare for someone here not to have seen your problem before and they are very willing and able to help.
            If my memory serves me correctly, the current version of RH came out in January 2007. Adobe are actively developing the product after a period of transition since they bought Macromedia and things are looking up. I'm really looking forward to seeing what Adobe turns up in future releases.
            • 3. Re: From Robo5 to Robo6
              Sorry Brian. Didn't see you there!
              • 4. Re: From Robo5 to Robo6
                No probs Colum,
                I don't use Source Control, and apart from the pre-release, RH6. I just searched for advice. Personal observations are much better advice.
                • 5. From Robo5 to Robo6
                  CraigCC Level 2
                  Hi Kay,
                  Robohelp 6 was released on January 15th 2007. Check out this thread for reasons to upgraded and information on new features:
                  http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=65&catid=447&threadid =1233179&highlight_key=y&keyword1=robohelp%206
                  If you are looking for an introduction to user defined variables, check out this article:
                  If you would like some information on the new improved Robohelp Source Control features of Robohelp 6 check out this link:
                  Hope that helps
                  • 6. Re: From Robo5 to Robo6
                    Hi KayNay and welcome to our community
                    I see others have already responded to your post. My reason for adding to the thread is because I'm not seeing something you mentioned specifically addressed.
                    You said:
                    ...it seems Screen Captures ( I currently use SnagIT and they can be blurry after inserted into Robo)...
                    I also currently use SnagIt. But I have to say that I don't believe RoboHelp 6 (or any version of RoboHelp or any other HAT) will assist in making your screen captures not "blurry". From what you have posted, I'm wondering if you are resizing the screen captures after you are inserting them into your help system. If so, this is not best practice. You should be resizing them before you insert them into help. If you do this, the clarity is much improved.
                    Cheers... Rick
                    • 7. Re: From Robo5 to Robo6
                      Catfish Tales Level 1
                      There might be advantages in waiting for the next release of RoboHelp ( read more).
