2 Replies Latest reply on Sep 15, 2011 4:26 PM by fresher4flex
    AdvancedDataGrid Problem: DropDownList ItemRenderer/Editor with Grouping
    WebTrauma Level 1
      I am having a problem getting the AdvancedDataGrid to render when I use a Spark dropdownlist as an item renderer/editor within GroupedData. The ADG has been extended to hold an ArrayCollection for my ddlist. That part works fine.
      The ddlist control appears both on the child node (good) as well as the parent node (bad).
      I have studied the examples and can't find anything wrong with my code.
      Is this a bug or am I missing something?
      Thanks!
      AdvancedDataGrid:
      <util:MyAdvDataGrid x="10" y="25" width="98%" id="dgItem" paddingLeft="25" paddingRight="25" paddingTop="25" paddingBottom="25"
                                      itemList="{acItem}"
                                      initialize="gc.refresh();"
                                      sortExpertMode="true"
                                      creationComplete="dgRule_creationCompleteHandler(event)"
                                      height="580">
                <util:dataProvider>
                     <mx:GroupingCollection2 id="gc" source="{acStuff}">
                          <mx:grouping>
                               <mx:Grouping label="Group Name">
                                    <mx:GroupingField name="myGroupName"/>
                               </mx:Grouping>
                          </mx:grouping>
                     </mx:GroupingCollection2>
                </util:dataProvider>
                <util:columns>
                     <mx:AdvancedDataGridColumn id="groupCol" headerText="Group" dataField="myGroupName"/>
                     <mx:AdvancedDataGridColumn id="col1" headerText="Column 1" dataField="itemName" itemRenderer="components.MyItemEditor"
                                                      rendererIsEditor="true" editable="true"/>
                     <mx:AdvancedDataGridColumn id="col2" headerText="Column 2" dataField="field2"
                                                      editable="false"/>
                     <mx:AdvancedDataGridColumn id="col3" headerText="Column 3" dataField="field3"
                                                      editable="false"/>
                     <mx:AdvancedDataGridColumn id="col4" headerText="Column 4" dataField="field4"
                                                      editable="false"/>
                </util:columns>
           </util:MyAdvDataGrid>
      ItemRenderer:
      <mx:HBox xmlns:fx="http://ns.adobe.com/mxml/2009"
                 xmlns:mx="library://ns.adobe.com/flex/mx" width="100" height="32"
                 paddingLeft="15">
           <fx:Script>
                <![CDATA[
                     import mx.collections.ArrayCollection;
                     import spark.events.IndexChangeEvent;
                     import utilities.MyAdvDataGrid;
                     [Bindable]
                     protected var acItem:ArrayCollection = new ArrayCollection();
                     override public function set data( value:Object ) : void
                          acItem = (owner as MyAdvDataGrid).itemList;
                     protected function dropdownlist_changeHandler(e:IndexChangeEvent):void
                     override protected function commitProperties():void
                          super.commitProperties();
           </fx:Script>
           <s:DropDownList id="ddlItem" prompt="Select..." dataProvider="{acItem}" labelField="itemName"
                               change="dropdownlist_changeHandler(event)"
                               width="90%" top="5" bottom="5" left="5" right="5"/>
      </mx:HBox>
        • 1. Re: AdvancedDataGrid Problem: DropDownList ItemRenderer/Editor with Grouping
          WebTrauma Level 1
          Update: If I declare the itemEditor inline, it no longer shows up on the collapsed row. However, it does not render at all unless it is clicked on. Once it is rendered, it does not hide itself when the group is collapsed.
          I have tried every permutation of editable="true" at the grid level, rendererIsEditor="true" and "false", explicitly definining (and not) an itemRenderer so that it will show the current value when the cell is not clicked, etc.
          Nothing will give me the desired behavior:
          show/hide ddlist when the group is expanded/collapsed
          OR
          show a TextArea with the current value, then the ddlist itemEditor when the cell is clicked.
                                          itemList="{acItem}"
                                          height="580">
                    <util:dataProvider>
                              <mx:grouping>
                                   </mx:Grouping>
                              </mx:grouping>
                    <util:columns>
                         <mx:AdvancedDataGridColumn headerText="Item Name" dataField="itemName" editorDataField="itemName" editable="true">
                              <mx:itemEditor>
                                   <fx:Component>
                                        <components:ItemEditorItems/>
                                   </fx:Component>
                              </mx:itemEditor>
                         </mx:AdvancedDataGridColumn>
                                                          editable="false"/>
                                                          editable="false"/>
                                                          editable="false"/>
                    </util:columns>
          • 2. Re: AdvancedDataGrid Problem: DropDownList ItemRenderer/Editor with Grouping
            fresher4flex
            Hi , I am have some problem when I use Dropdownlist  as Itemrendere in Advanced datagrid. If you have figured it out , do let me know
            Type Coercion failed: cannot convert spark.components::DropDownList@15d04851 to mx.controls.listClasses.IListItemRenderer.
