1 Reply Latest reply on Nov 5, 2010 6:24 AM by Claudiu Ursica
    HTTP Service vs URLLoader
    VirtualCoder Level 1
      Hi Folks,
      Besides confusing us noobs, why on earth would aAdobe have 2 classes that pretty much do the same thing? Did they badly screw up the first one or is it a simple case of left hand not knowing what right hand is doing?  In any case, which one would you recommend and why?
      VC
        • 1. Re: HTTP Service vs URLLoader
          Claudiu Ursica Level 4
          HTTP service is the higher level function . You get only 2 handlers result and
          fault (need to introspect yourself the root of the error) and also a
          requestTimeout to specify the timeout for the request. Some other extra goodies
          are attached check the docs. URLLoader is lower level embedded inside flash
          player. You have to add your own timeout logic, but you have explicit error
          handlers.
          Which one to use? depends on the context I guess. Dig into the docs for more
          example and you probably figure it out yourself.
          C
          To: Claudiu Ursica <the_braniak@yahoo.com>
          Sent: Fri, November 5, 2010 1:12:39 PM
          Subject: HTTP Service vs URLLoader
          Hi Folks,
          VC
