4 Replies Latest reply on Nov 5, 2010 1:34 PM by joesickspack
    Applescript: Indesign CS4 Set Text Wrap with Alpha Channel?
    joesickspack Level 1
      Is it possible to set an object's text wrap properties with Applescript?
      I want to set these wrap properties:
      Wrap type: Wrap around object shape
      Offset: .1"
      Wrap to: Both left & right sides
      Contour type: Alpha Channel
      Alpha Channel Name: "MyAlpha"
      Include inside edges: False
      I want to set the same wrap properties for every graphic in a file, so I was hoping to do something like this:
      tell application "Adobe InDesign CS4"
      activate
      tell active document
      repeat with thisGraphic in all graphics of every page
      try
      set (properties of thisGraphic) to {WHAT GOES HERE?}
      end try
      end repeat
      end tell
      end tell
        • 1. Re: Applescript: Indesign CS4 Set Text Wrap with Alpha Channel?
          Muppet Mark-QAl63s Level 4
          I did not have much time to test this (supposed to be working!!!) but it should be pretty close…
          tell application "Adobe InDesign CS2"
          tell the active document
          set ag to all graphics
          repeat with gi in ag
          if alpha channel path names of contour options of text wrap preferences of gi contains "MyAlpha" then
          set text wrap type of text wrap preferences of gi to contour
          set text wrap offset of text wrap preferences of gi to 1
          set inverse of text wrap preferences of gi to false
          set contour type of contour options of text wrap preferences of gi to alpha channel
          set contour path name of contour options of text wrap preferences of gi to "MyAlpha"
          set include inside edges of contour options of text wrap preferences of gi to false
          end if
          end repeat
          end tell
          end tell
          It should ONLY apply text wrap to graphics that have an Alpha Channel with your quoted name. You may have to deal with your units prefs for the offfset thou…
          • 2. Re: Applescript: Indesign CS4 Set Text Wrap with Alpha Channel?
            Thank you. That worked great with two minor changes:
            This line:
            causes this error:
            "Adobe InDesign CS4 got an error: The property is not applicable in the current state."
            so I added try . . . end try.
            And for CS4 "text wrap style" has to be changed to "text wrap mode"
            So here's what works:
            try
            set text wrap mode of text wrap preferences of gi to contour
            set text wrap offset of text wrap preferences of gi to .1
            end if
            end try
            end repeat
            end tell
            end tell
            • 3. Re: Applescript: Indesign CS4 Set Text Wrap with Alpha Channel?
              After posting my reply I happened to notice the same thing. It would appear that it does NOT like setting the contour path name to something it already is so I wrapped just that one line in an if statement… Glad you have it working anyhow… Oh my text appears to have gone all friday mad!!!?
              • 4. Re: Applescript: Indesign CS4 Set Text Wrap with Alpha Channel?
                Yeah, wrapping the one line makes more sense.
                The forum bolding is all haywire. Plus, I've never been able to get the indenting to work.
