5 Replies Latest reply on Nov 14, 2010 11:48 AM by low Jackson
    Adding hyperlinks to text via spreadsheet
    low Jackson
      Hi
      I have built a 52 page product document, and now have been asked to produce a PDF version with Hyperlinks on all the 300+ product names.
      The client is able to supply a spreadsheet of all the product names and URL in columns (XLS). Is there a way to find the Product Name in the doc and add the URL in to the hyperlinks panel.
      thanks
      Shane
        • 1. Re: Adding hyperlinks to text via spreadsheet
          Muppet Mark-QAl63s Level 4
          Here is some of the syntax for you. What you will need to add or find someone else to add is some find text function. This worked with a basic test for me. As is… it expects an open document with a text frame containing more words than you have rows in your excel doc. Save your spread sheet as CSV to test it. Hope you manage to get some mileage out of it…
          #target indesign
          function main() {
               if (app.documents.length == 0) {
                    return;
               }else{
                    var doc = app.activeDocument;
                    var csv = selectCSV();
                    if (csv != null)     {
                         var csvArray = readInDelimitedText(csv, ',')
                         for (var i = 0; i < csvArray.length; i++) {
                              // Your Hyperlink name      from excel column 1
                              var hn = csvArray[i][0];
                              // Your Hyperlink URL     from excel column 2
                              var url = csvArray[i][1];
                              // Not too sure about this method…
                              var find = RegExp(hn,'gi');
                              if (!inArray(doc.hyperlinks.everyItem().name, find)) {
                                   // This needs replacing with some find function?
                                   // I only have CS2 better let someone else do this part?
                                   // Set a text source
                                   var ts = doc.textFrames[0].words[i];
                                   addHyperlink(doc, ts, url, hn);
                              }else{
                                   alert('Hyperlink name is in use…')
          main();
          function selectCSV() {
               if (isMac()) {
                    var csv = File.openDialog('Select an CSV file', function(f) {return (f instanceof Folder)||f.name.match(/\.csv$/i);});
               }else{
                    var csv = File.openDialog('Open Comma-delimited File', 'comma-delimited(*.csv):*.csv;');
               return csv;
          function addHyperlink(doc, ts, url, hn) {
               // Create the Hyperlink
               var hts = doc.hyperlinkTextSources.add(ts);
               var urld = doc.hyperlinkURLDestinations.add(url);
               var hl = doc.hyperlinks.add(hts, urld);
               // Edit the look of it here…
               hl.borderColor = [255,0,255];
               hl.borderStyle = HyperlinkAppearanceStyle.dashed;
               hl.highlight = HyperlinkAppearanceHighlight.outline;
               hl.name = hn;
               hl.width = HyperlinkAppearanceWidth.medium;
               hl.visible = true;
          function readInDelimitedText(f, d) {
               var c = Array();
               f.open('r');
               while(!f.eof) {
                    c.push(f.readln().split(d));
               f.close();
               return c;
          function inArray(arr, exp) {
               return exp.test(arr.join(''));
          function isMac() {
            return /(Macintosh)/i.test($.os);
          • 2. Re: Adding hyperlinks to text via spreadsheet
            low Jackson Level 1
            Hi, can anyone help add a repeat loop to this (I forgot to mention I'm more applescript that javascript), as it only work on a single text frame at the moment.
            thanks again
            Shane
            • 3. Re: Adding hyperlinks to text via spreadsheet
              low Jackson Level 1
              Oh and thanks Mark great start!!!
              • 4. Re: Adding hyperlinks to text via spreadsheet
                With my pretty dated CS2 I was able to simply change…
                to
                var ts = doc.search(hn, true, true);
                if (ts.length > 0) {
                     // Just use the first item
                     addHyperlink(doc, ts[0].texts, url, hn);
                And it would do a find based on the contents of column 1 of the Excel spread sheet. These were 'unique' strings in my basic test doc. I did not post this as I believe the find thing in ID has undergone some major changes to what I have. I do think you would need to provide more info on how to find these items within your working document tho… I could have done the same thing in AppleScript but would have only come unstuck at the same issue…
                • 5. Re: Adding hyperlinks to text via spreadsheet
                  low Jackson Level 1
                  Hi Mark
                  I've tried swapping in your script but it breaks in cs5.
                  From my knowledge of applescript, find and replace now has a findType, eg. --findType is "text", "grep", or "glyph" (this sets the type of find/change operation to use).
                  I've attached the FindChangeByList script below as this must use this method…
                  --FindChangeByList.applescript
                  --An InDesign CS5 AppleScript
                  --Loads a series of tab-delimited strings from a text file, then performs a series
                  --of find/change operations based on the strings read from the file.
                  --The data file is tab-delimited, with carriage returns separating records.
                  --The format of each record in the file is:
                  --findType<tab>findProperties<tab>changeProperties<tab>findChangeOptions<tab>description
                  --Where:
                  --<tab> is a tab character
                  --findProperties is a properties record (as text) of the find preferences.
                  --changeProperties is a properties record (as text) of the change preferences.
                  --findChangeOptions is a properties record (as text) of the find/change options.
                  --description is a description of the find/change operation
                  --Very simple example:
                  --text {find what:"--"} {change to:"^_"} {include footnotes:true, include master pages:true, include hidden layers:true, whole word:false} Find all double dashes and replace with an em dash.
                  --More complex example:
                  --text {find what:"^9^9.^9^9"} {applied character style:"price"} {include footnotes:true, include master pages:true, include hidden layers:true, whole word:false} Find $10.00 to $99.99 and apply the character style "price".
                  --All InDesign search metacharacters are allowed in the "find what" and "change to" properties.
                  --For more on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
                  --or visit the InDesign Scripting User to User forum at http://www.adobeforums.com
                  tell application "Adobe InDesign CS5"
                  --Set the user interaction level to allow InDesign to display dialog boxes and alerts.
                  set user interaction level of script preferences to interact with all
                  set myTextObjects to {text, text frame, insertion point, character, word, text style range, line, paragraph, text column, cell, table, row, column}
                  if (count documents) is not 0 then
                  if (count stories of active document) is not 0 then
                  set mySelection to selection
                  if (count mySelection) is not 0 then
                  if class of item 1 of mySelection is in myTextObjects then
                  if class of item 1 of mySelection is text frame then
                  set myObject to object reference of text 1 of item 1 of mySelection
                  else if class of item 1 of mySelection is insertion point then
                  set myObject to parent story of item 1 of mySelection
                  else
                  set myObject to item 1 of mySelection
                  end if
                  my myDisplayDialog(myObject, myTextObjects)
                  else
                  set myObject to active document
                  end if
                  else
                  my myFindChangeByList(myObject)
                  end if
                  else
                  display dialog ("The current document contains no text. Please open a document containing text and try again.")
                  end if
                  else
                  display dialog ("No documents are open. Please open a document and try again.")
                  end if
                  end tell
                  on myDisplayDialog(myObject, myTextObjects)
                  if class of myObject is insertion point then
                  set myObject to parent story of myObject
                  end if
                  set myDialog to make dialog with properties {name:"FindChangeByList"}
                  tell myDialog
                  tell (make dialog column)
                  set myRangeButtons to make radiobutton group
                  tell myRangeButtons
                  make radiobutton control with properties {static label:"Entire document", checked state:true}
                  make radiobutton control with properties {static label:"Selected story"}
                  if class of myObject is in myTextObjects and class of myObject is not insertion point then
                  set myContents to contents of myObject
                  if myContents is not equal to "" then
                  make radiobutton control with properties {static label:"Selection", checked state:true}
                  end if
                  end if
                  end tell
                  end tell
                  end tell
                  set myResult to show myDialog
                  if myResult is true then
                  set myRange to selected button of myRangeButtons
                  destroy myDialog
                  if myRange is 0 then
                  set myObject to document 1
                  else if myRange is 1 then
                  if class of myObject is not story then
                  end if
                  end if
                  else
                  destroy myDialog
                  end if
                  end tell
                  end myDisplayDialog
                  on myFindChangeByList(myObject)
                  local myFile, myFileRef, myEOF, myFindType
                  set myFile to my myFindFile("FindChangeSupport:FindChangeList.txt")
                  set myFileRef to open for access (myFile as alias)
                  set myEOF to get eof myFileRef
                  set myOldDelimiters to AppleScript's text item delimiters
                  --That's a tab character between the quotation marks in the next line.
                  set AppleScript's text item delimiters to {" "}
                  if myEOF > 0 then
                  --Delimiter is return--if you have trouble reading your find/change file, it's
                  --probably because your line end characters are not Mac OS line end characters.
                  set myText to read myFileRef using delimiter {return}
                  close access myFileRef
                  repeat with myCounter from 1 to (count myText)
                  set myLine to item myCounter of myText
                  if myLine starts with "text" or myLine starts with "grep" or myLine starts with "glyph" then
                  if word 1 of myLine is "text" or word 1 of myLine is "grep" or word 1 of myLine is "glyph" then
                  set {myFindType, myFindPreferences, myChangePreferences, myFindChangeOptions, myDescription} to text items of myLine
                  if myFindType is "text" then
                  my myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
                  else if myFindType is "grep" then
                  my myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
                  else if myFindType is "glyph" then
                  my myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
                  end if
                  end if
                  end if
                  end repeat
                  end if
                  set AppleScript's text item delimiters to myOldDelimiters
                  end tell
                  end myFindChangeByList
                  on myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
                  --Clear the find text/change text preferences before each find/change operation.
                  set find text preferences to nothing
                  set change text preferences to nothing
                  set myScript to "tell application \"Adobe InDesign CS5\"" & return & "set properties of find text preferences to " & myFindPreferences & return
                  set myScript to myScript & "set properties of change text preferences to " & myChangePreferences & return
                  set myScript to myScript & "set properties of find change text options to " & myFindChangeOptions & return
                  set myScript to myScript & "end tell" & return
                  do script myScript language applescript language
                  tell myObject
                  set myFoundItems to change text
                  end tell
                  --Clear the find text/change text preferences after each find/change operation.
                  end tell
                  end myFindText
                  on myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
                  --Clear the find grep/change grep preferences before each find/change operation.
                  set find grep preferences to nothing
                  set change grep preferences to nothing
                  set myScript to "tell application \"Adobe InDesign CS5\"" & return & "set properties of find grep preferences to " & myFindPreferences & return
                  set myScript to myScript & "set properties of change grep preferences to " & myChangePreferences & return
                  set myScript to myScript & "set properties of find change grep options to " & myFindChangeOptions & return
                  tell myObject
                  set myFoundItems to change grep
                  end tell
                  --Clear the find grep/change grep preferences after each find/change operation.
                  end tell
                  end myFindGrep
                  on myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions)
                  --Clear the find glyph/change glyph preferences before each find/change operation.
                  set find glyph preferences to nothing
                  set change glyph preferences to nothing
                  set myScript to "tell application \"Adobe InDesign CS5\"" & return & "set properties of find glyph preferences to " & myFindPreferences & return
                  set myScript to myScript & "set properties of change glyph preferences to " & myChangePreferences & return
                  set myScript to myScript & "set properties of find change glyph options to " & myFindChangeOptions & return
                  tell myObject to change glyph
                  --Clear the find glyph/change glyph preferences after each find/change operation.
                  end tell
                  end myFindGlyph
                  on myFindFile(myFindFileName)
                  try
                  set myScript to active script
                  on error
                  set myScript to path to me
                  end try
                  end tell
                  tell application "Finder"
                  set myScript to file myScript
                  set myParentFolder to (container of myScript) as string
                  set myFileName to myParentFolder & myFindFileName
                  set myResult to exists myFileName
                  else
                  set myFileName to choose file with prompt "Locate your find/change file"
                  end if
                  end tell
                  return myFileName
                  end myFindFile
                  thanks
                  shane
