2 Replies Latest reply on Nov 5, 2010 11:50 PM by Shongrunden
    Custom Events: Parent issuing an event and child registering/handling
    larryl61
      Can somebody please tell me what I'm doing wrong!!
      I'm am creating an custom event in a parent app and
      want the child to register for it and handle the event
      when sent!
      main app:
                  xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
                  xmlns:local="*">
         <fx:Declarations>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
         </fx:Declarations>
         <s:layout>
            <s:VerticalLayout />
         </s:layout>
         <fx:Metadata>
            [Event(name="ev", type="flash.events.Event")]
         </fx:Metadata>
         <fx:Script>
            <![CDATA[
               public var aa:int = 0;
               private function sendEvt():void
                  var evt:Event = new Event("ev");
                  var ret:Boolean = dispatchEvent(evt);
         </fx:Script>
         <s:Button label="Button 1" click="sendEvt()"/>
         <local:Component1 width="100%" height="100%">
         </local:Component1>
      </s:Application>
      Child APP *********************************************
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
             xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300"
             creationComplete="init()">
         <fx:Declarations>
         </fx:Declarations>
         <fx:Script>
            <![CDATA[
               import mx.controls.Alert;
               private function init():void
                  this.addEventListener("ev",evtHandler);
               public function evtHandler(evt:Event):void
                  Alert.show("HI");
         </fx:Script>
      </s:Group>
        • 1. Re: Custom Events: Parent issuing an event and child registering/handling
          Claudiu Ursica Level 4
          Usually you do the other way around. Child talks to the parent through events.
          Parent calls methods directly on the child..
          So assuming that
          If  <local:Component1 id="theKid" width="100%" height="100%">
             </local:Component1>
          is the instance of your child group you can do this
          <s:Button label="Button 1" click="clickHandler(event)"/>
          private function clickHandler(event:MouseEvent):void
              theKid.publicMethodToCall();
          inside the child you declare the method as public
          public publicMethodToCall():WhateverType
              trace("Called by the parent");
          Unless I misunderstood somehow your use case.
          C
          • 2. Re: Custom Events: Parent issuing an event and child registering/handling
            Shongrunden Adobe Employee
            Your dispatching the event on the Application, but not listening on the Application.  Try dispatching the event on the same object you are listening on:
            var ret:Boolean = myComponent1.dispatchEvent(evt);
            <local:Component1 id="myComponent" width="100%" height="100%">
            </local:Component1>
