0 Replies Latest reply on Nov 5, 2010 8:26 AM by serefarikan
    Annoyingly long build loop in Flash Builder
    serefarikan
      Greetings,
      My Flash Builder environment used to function quite smoothly. However, recently it has started to exhibit this behaviour where it begins to build the project, and either never finishes to do so, or finishes after a minute or two!
      As you can imagine, this is very annoying. The process seems to begin and at random points like when X percent is complete, it restarts itself. It is almost as if the build process is triggering something that changes a resource and the build begins again.
      Is this a known issue? Any suggestions, fixes? Cleaning up the project used to work sometimes, but now it fails to delete the html file in the bin directory, and I end up spending my work hours wrestling with Flash Builder.
      Your help would be much appreciated.
      Kind regards
      Seref
