6 Replies Latest reply on Feb 4, 2011 6:55 AM by dtcullen
    Flash Builder Burrito - Enabled Geolocation in running device?
    Teerasej Jiraphatchandej Level 1
      Hi, I am developing a simple app that will show user's geolocation in the map.
      I use code like this:
      protected function view1_creationCompleteHandler(event:FlexEvent):void
           if( Geolocation.isSupported )
                 g = new Geolocation();
                 g.setRequestedUpdateInterval(100);
                 if( g.muted )
                     // Don't do anything if device's sensor is muted.
                      return;
                 g.addEventListener(GeolocationEvent.UPDATE,geoLocation_UpdateHandler,false,0,true);
      Then I modified application.xml in project like this (following Ryan Strewart's video in Adobe TV):
      <android>
          <manifestAdditions><![CDATA[
          <manifest android:installLocation="auto">
              <!-- See the Adobe AIR documentation for more information about setting Google Android permissions -->
              <uses-permission android:name="android.permission.INTERNET"/>
              <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"/>
              <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
              <uses-configuration android:reqFiveWayNav="true"/>
              <supports-screens android:normalScreens="true"/>
              <uses-feature android:required="true" android:name="android.hardware.touchscreen.multitouch"/>
          </manifest>
      ]]></manifestAdditions>
        </android>
      Then I use Flash Builder Burrito to install and run application into device. The Geolocation object is muted. Even I turn on all geolocation setting. An interesting thing is, Geolocation is work in Flex de tour Mobile application.
      I use Samsung Galaxy S with Froyo 2.2
        • 1. Re: Flash Builder Burrito - Enabled Geolocation in running device?
          pmcalenney1 Level 1
          I am having the same problem - Motorola Droid.
          No matter what, it reports back that Geolocation is muted, when it is on and active.  I test in google maps, works fine, but my app thinks it is muted.
          Anyone have any luck using Geolocation??
          • 2. Re: Flash Builder Burrito - Enabled Geolocation in running device?
            pmcalenney1 Level 1
            • 4. Re: Flash Builder Burrito - Enabled Geolocation in running device?
              kraikit Level 2
              I was able to test the Geolocation object successfully on a Motorola Droid using the following code:
              GeoTest1.mxml:
              <s:MobileApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                   xmlns:s="library://ns.adobe.com/flex/spark" firstView="views.GeoTest1Home">
                  <fx:Declarations>
                      <!-- Place non-visual elements (e.g., services, value objects) here -->
                  </fx:Declarations>
              </s:MobileApplication>
              GeoTest1Home.mxml:
              <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:s="library://ns.adobe.com/flex/spark" title="Home"
                      creationComplete="view1_creationCompleteHandler(event)">
                  <fx:Script>
                      <![CDATA[
                          import flash.sensors.Geolocation;
                          import mx.events.FlexEvent;
                          private var g:Geolocation;
                                  if( g.muted )
                                      msg.text = "geo muted";
                                      return;
                                  msg.text = "geo active";
                                  g.addEventListener(GeolocationEvent.UPDATE,geoLocation_UpdateHandler, false,0,true);
                          protected function geoLocation_UpdateHandler(event:Event):void
                              msg.text += "\ngeolocation updated";
                  </fx:Script>
                  <s:Label id="msg" text="foo"/>
              </s:View>
              GeoTest1-app.xml
              <?xml version="1.0" encoding="utf-8" standalone="no"?>
              <application xmlns="http://ns.adobe.com/air/application/2.6">
                   <id>GeoTest1</id>
                   <filename>GeoTest1</filename>
                   <name>GeoTest1</name>
                   <versionNumber>1.0.0</versionNumber>
                   <initialWindow>
                        <content>[This value will be overwritten by Flash Builder in the output app.xml]</content>
                   </initialWindow>
                   <android>
                        <manifestAdditions>
                        <![CDATA[
                                  <application android:enabled="true">
                                       <activity android:excludeFromRecents="false">
                                            <intent-filter>
                                                 <action android:name="android.intent.action.MAIN"/>
                                                 <category android:name="android.intent.category.LAUNCHER"/>
                                            </intent-filter>
                                       </activity>
                                  </application>
                             </manifest>
                   </android>
              </application>
              Please try the above and see if it works.
              -- Tom
              Flex SDK engineer
              • 5. Re: Flash Builder Burrito - Enabled Geolocation in running device?
                EhlersD Level 1
                As a quick test, I embedded this into an existing test app I'm working on.  This GPS code worked perfectly on my HTC Evo 4G.
                - Darren
                • 6. Re: Flash Builder Burrito - Enabled Geolocation in running device?
                  dtcullen Level 1
                  This may help someone.  I had exactly the same problem which got fixed when I pasted in the *app.xml code posted above.  The default app.xml that is generated by Burrito does have  all of the config that you need BUT it is in a comment and there is a minimal config at the bottom;
                  <!-- Specify Android specific tags that get passed to AndroidManifest.xml file. -->
                  <!--<android>
                  <manifestAdditions>
                  <![CDATA[
                  <intent-filter>
                  </intent-filter>
                  </activity>
                  </application>
                  </manifest>
                  </android> -->
                  <!-- End of the schema for adding the android specific tags in AndroidManifest.xml file -->
                  ALL OF THE ABOVE IS A COMMENT AND THE ACTUAL CONFIG IS BELOW !!!!!!
                  <android>
                  <manifest>
                  </manifest>
                    </android>
                  </application>
                  I just removed the comments and the minimal config at the bottom and all was well.
