13 Replies Latest reply on Nov 7, 2010 9:24 AM by MurraySummers
    template update and kaosweaver
    harvey waxman Level 1
      When KW adds code to the head tag in a page that is linked to a template, does updating the template itself remove the KW code in the linked page?  It appears not to but I would like confirmation.
        • 1. Re: template update and kaosweaver
          MurraySummers Level 8
          Nope.  KW adds the code to the editable region in the head of the page.  Updating the template does not touch editable region contents.
          • 2. Re: template update and kaosweaver
            Thanks so much for the rapid reply.  The reason I ask is because the code shows the KW functions in the greyed out area of the page but they aren't in the template <head> itself.  And I never typed them in, of course.
            I'm using DW8 on a Mac / Leopard.
            • 3. Re: template update and kaosweaver
              Is this code within an editable region? If it is, it's safe.  If it's not, we have witnessed a miracle.
              • 4. Re: template update and kaosweaver
                The code is not editable in the page with the KW calculator.  The code doesn't appear in the template itself.
                I just created a new page and applied the template.  I then created a form and use KW to do the math.  I looked in the template part and this appeared in grey non-editable area:
                function MM_findObj(n, d) { //v4.01
                  var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
                    d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
                  if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
                  for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
                  if(!x && d.getElementById) x=d.getElementById(n); return x;
                function KW_getVal(o){ //v1.2
                var retVal="0";if (o.type=="select-one")
                {retVal=(o.selectedIndex==-1)?0:o.options[o.selectedIndex].value;}
                else if (o.length>1){for (var i=0;i<o.length;i++) if (o[i].checked) retVal=o[i].value;
                } else if (o.type=="checkbox") {retVal=(o.checked)?o.value:0;} else {
                retVal=Number(o.value)}return parseFloat(retVal);
                I then deleted the KW behavior and the form and the above text was gone.
                Not being religious, a miracle would be very hard to explain
                • 5. Re: template update and kaosweaver
                  I'll bet it is. You are misunderstanding my question.  I asked "Is it in an editable region".  You replied "It is in a gray non-editable region".  But it could still be gray even though it's in an editable region.  Please either show us this code, or evaluate whether there is an editable region tag around this code.  See - people still insert javascript as if it were 1990, by placing it within HTML comments - that makes it gray in DW's Code view, e.g.,
                  window.onload=("This is gray!");
                  </script>
                  It is still editable however, right?  If it's not, then I have to see it to believe it.
                  • 6. Re: template update and kaosweaver
                    I went to the code in the head, placed the cursor near text and tried to delete it.  It beeped at me but would do nothing.  Let me know how I can help solve the problem.  Screen shot?  Mail the code to you?  Don't know what the forum allows.
                    The web page is here:
                    http://righttax.org/calc.html
                    I copied the source from the page, saved to a text file and it too does the same thing in DW.  I swear I didn't write the code to the HEAD tag, honest.
                    • 7. Re: template update and kaosweaver
                      That is seriously weird.  Your template is flawed, though.
                      There is no editable region around the <title> tag - this means that you cannot change the title on any child page (try it!), and there is no secondary editable region called "head" in the head of the page, both of which are required for normal template functionality.  How the javascript gets in there escapes me - you cannot add any content to non-editable regions of a template child page.
                      Post the code for the template here so we can see what you have....
                      • 8. Re: template update and kaosweaver
                        Flawed it may be but DW wrote it.  Clearly I'm not capable.  Here is the .dwt file  and you can see the KW functions aren't there.
                        <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
                        <html>
                        <head>
                          <meta name="description"
                        content="Change property tax laws to make them more fair for everyone">
                          <meta name="Keywords"
                        content="TAXES,taxing, tax, taxed, Rhode Island, property, property tax, taxes, fairness, fair, equity, common sense, equal, equality, reasonable, government, expenses, history, ad valorem, unfair, honesty, together, local, teachers, education, fire, police, income, sales, taxing, taxed, housing, sales, value, assessment, assessments, revaluation, appraisal, assessor, burden, constitution, taxing power">
                          <meta http-equiv="Content-Type"
                        content="text/html; charset=ISO-8859-1">
                        <meta name="ttw" content="4x8681g" />
                          <style type="text/css">
                        .style3 {font-size: 13px}
                        .style8 {font-size: 12px}
                        h3 {margin: 0; padding: 0;}
                        .style9 {font-size: medium}
                        .style10 {color: #0000CC}
                        .style12 {color: #000000}
                        .special {display: none}
                          </style>
                          <title>Property Tax Reform That Works For Everyone</title>
                          var _gaq = _gaq || [];
                          _gaq.push(['_setAccount', 'UA-17268631-1']);
                          _gaq.push(['_trackPageview']);
                          (function() {
                            var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
                            ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
                            var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
                        </script>
                        </head>
                        <body bgcolor="#006666" style="background-color: rgb(0, 102, 102);">
                        <table align="center" bgcolor="#dcdcdc" border="1" cellpadding="8"
                        cellspacing="0" width="800">
                          <tbody>
                            <tr bgcolor="#cccccc">
                              <td height="86" colspan="3" valign="top" bgcolor="#dcdcdc">
                              <p align="center"> </p>
                              <h2 align="center"><font color="#000099">R</font>hode      <font color="#000099">I</font>sland <font color="#000099">G</font>ets <font color="#000099">H</font>onorable <font color="#000099">T</font>axation
                              <em><br>
                              </em><img src="../Images/ri1.jpg" alt="images"
                        width="262" height="171"><img src="../Images/ri4Wickford.jpg" alt="images"
                        width="140" height="171"><img src="../Images/ri3.jpg" alt="images" width="227" height="171"></h2>
                              <table width="233" border="1" align="left" bgcolor="#DCDCDC">
                                <tr>
                                  <td bgcolor="#DCDCDC">
                           <!-- GOOGLE SEARCH -->
                          <div id="cse" style="width: 100%;">Loading search engine </div>
                          <script src="http://www.google.com/jsapi" type="text/javascript"></script>
                          google.load('search', '1', {language : 'en'});
                          google.setOnLoadCallback(function() {
                            var customSearchControl = new google.search.CustomSearchControl('003347859783936951347:b8mnj_l0n4o');
                            customSearchControl.setResultSetSize(google.search.Search.FILTERED_CSE_RESULTSET);
                            customSearchControl.draw('cse');
                          }, true);
                        </script>
                        <link rel="stylesheet" href="http://www.google.com/cse/style/look/default.css" type="text/css" />
                          <!-- GOOGLE SEARCH --></td>
                                </tr>
                              </table></td>
                            </tr>
                            <tr bgcolor="#dcdcdc">
                              <td width="20%" rowspan="2" valign="top"  class="sidebar">
                              <p> <span class="style3">&bull; <a href="../petition.html">See
                        Our Petition</a><br>
                        &bull; <a href="../faq.html">FAQ</a>
                              <br>
                              &bull; <a href="../editorial.html">Providence Journal Editorial 2005</a> <br>
                        &bull; <a href="../movie.html">
                        R.I.G.H.T. on TV</a> <br>
                        May12, 2009<br>
                          Mar  9, 2006<br>
                          Mar  3, 2006 </span>      </p>
                              <p align="center">
                        Links &bull; Blogs </p>
                              <div class="style3" align="left">
                              <p> &bull; <a
                        href="http://www.rilin.state.ri.us/Statutes/Statutes.html"
                        target="_blank">RI General Laws</a><br>
                        &bull; <a href="http://www.rilin.state.ri.us/" target="_blank">RI
                        General Assembly</a><br>
                        &bull; <a href="http://www.riedc.com/" target="_blank">RI Econ. Dev.
                        Corp.</a><br>
                        &bull; <a href="http://rifuture.org">RI Future Blog</a> <br>
                        &bull; <a href="http://www.anchorrising.com/">Anchor Rising Blog</a> <br>
                        &bull; <a href="http://www.commoncauseri.org/" target="_blank">RI
                                Common Cause </a><br>
                          &bull; <a href="http://www.ripec.com" target="_blank">RIPEC</a><br>
                          &bull; <a href="http://ocgri.org/" target="_blank">Operation Clean
                            Gvt. </a><br>
                          &bull; <a href="http://whatcheer.net/ripr" target="_blank">RI
                            Policy
                            Reporter</a><br>
                          &bull; <a href="http://www.rileague.org/site/links/citiestowns.html"
                        target="_blank">RI League of Cities and Towns</a><br>
                          &bull; <a href="http://www.ctj.org/" target="_blank">Citizens for Tax
                            Justice</a><br>
                          &bull; <a href="http://quickfacts.census.gov/qfd/states/44000.html"
                        target="_blank">US Census Facts</a><br>
                          &bull; <a href="http://www.nber.org/" target="_blank">Bureau Economic
                            Research</a><br>
                          &bull; <a href="http://hwaxman.blogspot.com" target="_blank">My Personal  Blog <br>
                                </a><br>
                              </p>
                              </div>
                              <hr width="100">
                          <p align="center">
                            <a href="http://validator.w3.org/check?uri=referer"><img
                                src="http://www.w3.org/Icons/valid-html401"
                                alt="Valid HTML 4.01 Transitional" height="31" width="88"></a>  </p>
                          <!-- Site Meter -->
                           I DELETED SOME TRACKING STUFF HERE
                              <a href="http://freewebsubmission.com"><font color="#666666" size="-7">FreeWebSubmission.com</font></a></td>
                              <td width="62%" height="51"
                        valign="baseline" bgcolor="#FFFFFF">
                              <div align="left"><!-- TemplateBeginEditable name="EditRegion" -->EditRegion<!-- TemplateEndEditable --></div>      </td>
                              <td
                              <p class="style3" align="left"><a href="../petition.html"><font color="#000000">We,
                        the </font>undersigned</a>, respectfully
                        request that the proposals offered by R.I.G.H.T. be used as a model to
                        stimulate legislative discussion, debate and ultimatelyto restore
                        fairness in property tax procedures.</p>
                              <hr>
                              <p class="style3" align="right">Kimberly
                        Aguiar<br>
                        Carmen Baker<br>
                        Jim Baker<br>
                        Korinne Barnes<br>
                        Diane Barzaghi<br>
                        Robert A. Benson, Jr <br>
                        Richard Bee<br>
                        Judith Bitting<br>
                        Alice Blair<br>
                        William F Bonneau<br>
                        Allan Brockman<br>
                        Kathleen S. Brown<br>
                        Andrie Butler<br>
                        David Butler<br>
                        Kathy Carniaux<br>
                        Bob Carniaux<br>
                        Steve Cevoli<br>
                        Kathy Cevoli<br>
                        Lance W. Chappell<br>
                        Howard Cohen<br>
                        William Connelly<br>
                        Heath Cooper<br>
                        David Darlington<br>
                        Debra Davis<br>
                        Hilarie Davis<br>
                        Laura Davis<br>
                        Joseph T. DeAlteris<br>
                        Sandra A. DeAlteris<br>
                        L&amp;F DeBoer<br>
                        Bradley Dracott<br>
                        Arlene Fall<br>
                        Victor P. Fasolino<br>
                        Elizabeth Finneran<br>
                        Tom Fitzgerald<br>
                        Eugene Fry<br>
                        David Gagnier<br>
                        Darlene Godin<br>
                        Donna Tocco-Greenaway<br>
                        William J. Greenaway<br>
                        Michael Griffin<br>
                        Vida-Wynne Griffin<br>
                        Scott J. Grzych<br>
                        G.M. Hadley<br>
                        Nancy Harrington<br>
                        Dale Harrington<br>
                        Katherine Harrop<br>
                        Robert Hutchison<br>
                        Marjorie Johnston<br>
                        Ann Jones<br>
                        Joanne Lamora<br>
                        Bruce Larson<br>
                        Carol Larson<br>
                        George W. Lavoie<br>
                        Michele Leavitt<br>
                        John Leventhal<br>
                        Rep. John Loughlin II<br>
                        Mark Lucas<br>
                        Kiersten Marek<br>
                        Linc Materna<br>
                        Nicolette Mathews<br>
                        John Maxwell<br>
                        Gerald Maxwell<br>
                        Mary Maxwell<br>
                        Stephen McKendall<br>
                        Kelly McGovern<br>
                        Shawn McGowan<br>
                        Anthony Micheletti<br>
                        Virginia Micheletti<br>
                        Dee Michelson<br>
                        Sanford Miller<br>
                        Barbara Montecalvo<br>
                        Thomas Mowry<br>
                        Bill Mudge<br>
                        Pam Neal<br>
                        Carl Neal<br>
                        Edwin Nicholson<br>
                        Gregg O'Neill<br>
                        Charles Ostiguy<br>
                        Yvonne Parker<br>
                        Anne Pascucci<br>
                        John Pascucci<br>
                        Raymond Rivet<br>
                        Raymond Schleicher<br>
                        Ronda Schuster<br>
                        Suren Semonian
                        <br>
                        Tom Sgouros<br>
                        Erin Sharaf<br>
                        Barry Sharaf<br>
                        Bill Sharp<br>
                        Tamara Sharp<br>
                        Shirley Sheehan<br>
                        John Sivo Jr.<br>
                        Marjorie A.Sivo<br>
                        Anthony M.Sivo<br>
                        Derek A.Sivo<br>
                        Mike Smith<br>
                        Paul Smith<br>
                        Amy N. Sonder<br>
                        Hilda M. Souza<br>
                        Richard A. Souza<br>
                        Eileen Spillane<br>
                        Wendy C. Sturn<br>
                        David Sullivan<br>
                        John Sweeney<br>
                        Lisa Tener<br>
                        Nicholas Tiernan<br>
                        Gary W. Trott<br>
                        Ellen Waxman<br>
                        Judy Waxman<br>
                        Harvey Waxman<br>
                        Holly R. Wiesendanger<br>
                        Bernhard Weiss<br>
                        Charles Weiss<br>
                        Maria Weiss<br>
                        Robert Wilson<br>
                        Michael Wood<br>
                        <br>
                        Know
                        someone hurt by soaring
                        property taxes? We'd love to talk to them. Contact us: <br>
                              <a href="../emailform.html">R.I.G.H.T</a></p>
                              <p class="style3" align="center">INSANITY:
                        using the same
                        solutions to a problem and expecting different results.</p>      </td>
                            </tr>
                            <tr>
                              <td bgcolor="#dcdcdc" valign="top">
                              <p align="center"><font face="Times"><a
                        href="../index.html">Home</a>  <a href="../Managers.html">Managers</a>   <a
                        href="../Lawmakers.html">Lawmakers</a>  <a href="../Business.html">Businesses</a>  <a
                        href="../Unions.html">Unions</a>  <a href="../Homeowners.html">Homeowners</a>  <a
                        href="../Realtors.html">Realtors</a>  </font><a
                        href="../faq.html">Faq</a></p>
                              <p align="center"><font face="Times"><span class="style9">To
                        schedule a talk and slide show <a href="../emailform.html">email</a>
                        or call 401 862 6825 </span></font></p>
                              <p align="center"><a href="http://www.rilin.state.ri.us/"
                        target="_blank">To
                        contact your Rhode Island Legislators (House and
                        Senate) click.</a> </p>
                              <p align="center">For
                        an alphabetical listing click here for <a
                        href="http://www.rilin.state.ri.us/house" target="_blank">House
                        - </a><a href="http://www.rilin.state.ri.us/senate" target="_blank">Senate<br>
                              </a><a href="../sample.html"><br>
                        For a sample letter you can send to your legislators</a>      </p>
                              <p align="center"><br>
                        Rhode Island Gets Honorable Taxation<strong><br>
                        R.I.G.H.T. &copy; 2006</strong><br>
                        <strong>L.E.F.T.</strong> <br>
                        Let's Everyone Fix Taxes<br>
                        <br>
                                The contents of the website are protected by US copyright laws.<br>
                                  <a href="../emailform.html">Email</a><br>
                                Harvey Waxman <br>
                                73 Wright Lane<br>
                                North Kingstown, RI 02852<br>
                              </p>
                              <p align="center"> </p>      </td>
                            </tr>
                          </tbody>
                        </table>
                        <!--GOOGLE TRACKING-->
                        I DELETED GOOGLE TRACKING CODE
                        </body>
                        </html>
                        • 9. Re: template update and kaosweaver
                          I forgot to ask, how do I fix the two problems you identified?
                          • 10. Re: template update and kaosweaver
                            DW is not the only one responsible for this flawed page.
                            Try this.  Create a new, blank HTML page and use FILE | Save as Template....  Look at the title tag.  Is it in an editable region?  Look in the head of the page.  Is there an editable region in it called "head".  The answer to both questions will be "yes".  Now look at your template.  Do you see either of those regions there?  No.  So either you (or someone) deleted them, or your template was created improperly.  Which DW are you using?  I recall there there was an issue with earlier versions of DW that could cause a template just like this to be created, but I forget how it came about.
                            Now - to get the KW code on the page, you spawned a child page from the template (NEW | Page from template..., etc.), then applied the KW behavior to this new child page?
                            • 11. Re: template update and kaosweaver
                              It looks like I must have made the wrong selections when I initially saved the template or applied to a page.
                              Am I better off leaving it as is since it's working, as far as I can tell?
                              If not,
                              Where do I insert editable regions you suggested be in the template?
                              When applying a template what do I think about when deciding on assigning parts?
                              I'm surprised DW allowed me to muck up the template - unless I just ignored warnings?  Not likely but
                              the site is several years old and I wouldn't swear to it.
                              You've been a great help.
                              • 12. Re: template update and kaosweaver
                                I would fix it.
                                In the template file, change this -
                                <title>Untitled Document</title>
                                to this -
                                <!-- TemplateBeginEditable name="doctitle" -->
                                and this -
                                </head>
                                to this -
                                <!-- TemplateBeginEditable name="head" -->
                                </head>
                                Now you should be set.
                                What will change on each page.  Those are editable regions.  Or do you mean that you are applying templates to existing pages?  That's MUCH more troublesome.
                                As I recall, DW8 would allow you to create a new template in such a way that it didn't contain those necessary regions - maybe it was File > New Template?
                                I dunno....
                                • 13. Re: template update and kaosweaver
                                  Thanks for all your help, as always.
