0 Replies Latest reply on Nov 7, 2010 8:26 AM by zorg128
    FM4 Site Coverage FlexPMD
    zorg128 Level 1
      I am setting up my first maven project and am having some trouble getting my site reports to display properly.  In short, my coverage and PMD reports are blank.
      When running 'mvn site' my tests run about three times (not sure why, do they need to?) Each time my tests run I get a new coverage folder with correct results; twice in my /target folder, once in my /target/site folder. Finally, the ASDocs report runs and copies a blank index.html to /target/site/coverage wiping out my coverage report.
      I also see PMD running thrice. I get a xml result in my /target which appears to be the output of an un-configured pmd run (default ruleset) and a html transformation for it.  In my /target/site folder I get my configured pmd.xml (correct results) and a flexpmd.html with the maven site shell but no results.
      ASDoc, FlexMetrics and Surefire reports all turn out okay.
      Clearly im missing some configurations somewhere. Any ideas would be helpful.
      Thanks!
      <properties>
          <flex.version>4.1.0.16076</flex.version>
          <flexmojos.version>4.0-SNAPSHOT</flexmojos.version>
          <flash.version>10.0.12.36</flash.version>
      </properties>
      <build>
      <plugin>
          <groupId>org.sonatype.flexmojos</groupId>
          <artifactId>flexmojos-maven-plugin</artifactId>
          <version>${flexmojos.version}</version>
          <extensions>true</extensions>
          <configuration>
              <linkReport>true</linkReport>
              <optimize>true</optimize>
              <debug>true</debug>
              <quick>false</quick>
              <ditaSkip>false</ditaSkip>
              <showWarnings>false</showWarnings>
              <coverage>true</coverage>
              <allowSourcePathOverlap>true</allowSourcePathOverlap>
              <defines>
                  <property>
                      <name>CONFIG::DEBUG</name>
                      <value>true</value>
                  </property>
              </defines>
              <targetPlayer>${flash.version}</targetPlayer>
              <flashPlayerCommand>${flashPlayer.command}</flashPlayerCommand>
          </configuration>
          <dependencies>
              <dependency>
                  <groupId>com.adobe.flex</groupId>
                  <artifactId>compiler</artifactId>
                  <version>${flex.version}</version>
                  <type>pom</type>
              </dependency>
              <dependency>
                  <groupId>com.adobe.flex.framework</groupId>
                  <artifactId>flex-framework</artifactId>
                  <type>pom</type>
              </dependency>
          </dependencies>
      </plugin>
      <plugin>
        <groupId>org.apache.maven.plugins</groupId>
        <artifactId>maven-site-plugin</artifactId>
        <version>3.0-beta-3</version>
        <executions>
           <execution>
             <id>default-site</id>
             <phase>site</phase>
             <goals>
                 <goal>site</goal>
             </goals>
             <configuration>
               <reportPlugins>
                 <plugin>
                     <artifactId>maven-project-info-reports-plugin</artifactId>
                     <version>2.2</version>
                 </plugin>
                 <plugin>
                     <artifactId>maven-surefire-report-plugin</artifactId>
                     <version>2.6</version>
                 </plugin>
                 <plugin>
                     <configuration>
                         <defines>
                             <property>
                                 <value>true</value>
                             </property>
                         </defines>
                     </configuration>
                 </plugin>
                 <plugin>
                     <groupId>com.adobe.ac</groupId>
                     <artifactId>flex-pmd-maven-plugin</artifactId>
                     <version>1.2</version>
                     <configuration>
                         <ruleSet>${project.build.outputDirectory}/pmd_ruleset.xml</ruleSet>
                         <outputDirectory>${project.reporting.outputDirectory}</outputDirectory>
                         <sourceDirectory>${project.build.sourceDirectory}</sourceDirectory>
                     </configuration>
                 </plugin>
                 <plugin>
                     <artifactId>flex-pmd-cpd-maven-plugin</artifactId>
                     <configuration>
                         <minimumTokenCount>50</minimumTokenCount>
                     </configuration>
                 </plugin>
                 <plugin>
                     <artifactId>flex-pmd-metrics-maven-plugin</artifactId>
                 </plugin>
               </reportPlugins>
             </configuration>
           </execution>
        </executions>
      </plugin>
      </build>
