3 Replies Latest reply on Nov 8, 2010 3:38 AM by nealeh
    Audio Export Question...
    zzwweerr
      I have a work, edited into 4 video clips on the timeline. I want 4 audio tracks to make a CD.
      I would love to either:
      1. Select each clip and then export that clip's audio so the clip audio's are available to make a cd.
      2. Or save each clip from the timeline, and then reload each clip one at a time and export it.
      Can PE do either?
      any suggestions?
      Workarounds?
        • 1. Re: Audio Export Question...
          You want each track separately, right? You don't want to export a mix of the audio.
          You'll need to right-click on all but the track you want to export and deselect Enable so that only the track you want is enabled. Then (depending on which version of the program you're using) go to Share/Computer/Audio to save it as an AVI.
          Do that for each track you want to save.
          You can then use iTunes or Windows Media Player to gather your AVIs and burn a CD.
          • 2. Re: Audio Export Question...
            zzwweerr Level 1
            My problem is not multiple tracks, but multiple trims of  clips (in and out points).
            From several shows, they have been collected and trimed in one workspace.
            If I could only select the first selected trimmed clip, and then either save it, or export the audio,
            and then select the next trimmed clip...
            The problem is that I can not figure out how to do either.
            I could start from scratch, retrim each clip one at a time, and then export, and get the next clip.
            that requires me to re-edit each clip, when it is already done.
            • 3. Re: Audio Export Question...
              nealeh Level 5
              In your timeline set the Work Area Bar to select only the area you want. Then when you Share tick the 'Share WorkAreaBar Only' box.
              To set the work area bar drag the ends:
              Cheers,
              Neale
