8 Replies Latest reply on Nov 8, 2010 3:06 PM by pprocessone
    Scripting to load all pdfs in a month into the place command?
    pprocessone
      Hello, I was wondering if anyone knows of a script that allows for you to place all pdfs within a set date range from a folder into an InDesign document? I am looking to do my monthly report and each month I have to go out and get each one, would be nice to load the place tool with all the pdfs I have done with a set date range and then just place them accordingly. Is there something out there like this and/or am I missing something obvious?
      Thanks!
      B
        • 1. Re: Scripting to load all pdfs in a month into the place command?
          Marijan Tompa [tomaxxi] Level 4
          Hey!
          This is not working code (maybe it is ), but it will give you good start:
          function compareDates ( a, b )
            if ( a.created < b.created )
              return 1;
            if ( a.created > b.created )
              return -1;
            return 0;
          var myFiles = File.openDialog("Select Files:", "", true);
          myFiles.sort(compareDates);
          if(myFiles != null)app.activeDocument.placeGuns.loadPlaceGun(myFiles);
          Hope that helps.
          tomaxxi
          http://indisnip.wordpress.com/
          • 2. Re: Scripting to load all pdfs in a month into the place command?
            pprocessone Level 1
            OK, So like lets say it was from November 1 to November 30 where would that
            go in this a-b ? I am sorry I am not a versed scripter at all.
            Best regards,
            Robert Borchardt
            To:         Robert Borchardt <robert.j.borchardt@jci.com>
            Date:       11/08/2010 09:39 AM
            Subject:    Scripting to load all pdfs in a month into the place command?
            Hey!
                return 1;
                return -1;
              return 0;
            Hope that helps.
            tomaxxi
            • 3. Re: Scripting to load all pdfs in a month into the place command?
              pprocessone Level 1
              I'm sorry this didn't work, and I need to mention I need like an example of
              where the date info should be inserted. I apologize I am not a scripter
              guru. BUT I appreciate your assistance!
              Best regards,
              Robert Borchardt
              414.524.4953
              Johnson Controls, Inc
              507 E  Michigan
              Milwaukee, WI  53202
              Hey!
                  return 1;
                  return -1;
                return 0;
              Hope that helps.
              tomaxxi
              • 4. Re: Scripting to load all pdfs in a month into the place command?
                Sorry for delay...
                I just tested script and it's working fine for me here.
                I created 4 sample PDF-s with just one page, then started script,
                selected exported PDF-s, script sorts them by creation date and loads placegun.
                So, all you need to do, is to start script and select documents you want to place.
                I changed script little, so make sure you use this one:
                if(app.documents.length != 0){
                    var myFiles = File.openDialog("Select Files:", "*.pdf", true);
                    if(myFiles != null){
                        myFiles.sort(function ( a, b )
                                    return -1;
                                    return 1;
                                return 0;
                        app.activeDocument.place(myFiles);
                    }else{
                        alert("No files selected!");
                }else{
                    alert("No documents opened!");
                tomaxxi
                • 5. Re: Scripting to load all pdfs in a month into the place command?
                  pprocessone Level 1
                  IM Sorry tomaxxi, am I suppose to be inputting something somewhere here in
                  regard to the dates? I would need an example like for lets say the month of
                  Nov. I try to paste this and save it in the script editor but it keep
                  saying that the file cannot be saved. Any ideas? Please bear in mind your
                  speaking to a guy who has like zero knowledge when it comes to scripts.
                  Best regards,
                  Robert
                  Date:       11/08/2010 03:29 PM
                  Sorry for delay...
                  placegun.
                  place.
                                      return -1;
                                      return 1;
                                  return 0;
                      }else{
                  }else{
                  tomaxxi
                  • 6. Re: Scripting to load all pdfs in a month into the place command?
                    Read http://indesignsecrets.com/how-to-install-scripts-in-indesign.php, it gives you the a-b-c to get started with saving and using scripts.
                    (By the way: can you not include the entire previous mail plus your personal contact info in your reply? It all shows up in the forum ...)
                    • 7. Re: Scripting to load all pdfs in a month into the place command?
                      Well, you don't have to input anything to script.
                      Here is little guide how to save and run script:
                      1. Open Adobe ExtendScript Toolkit (You can also use simple text editor)
                      2. Copy script I sent you, and paste it in editor
                      3. Save it to {InDesign Installed Folder}\Scripts\Scripts Panel\placePDF.jsx
                      4. Go to InDesign
                      5. {CS5} Go to menu Window -> Utilities -> Scripts
                      5. {CS4} Go to menu Window -> Automation -> Scripts
                      6. Find script {placePDF.jsx} and run it.
                      Hope that helps.
                      tomaxxi
