• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
JQuery - CFML - form submit example
Participant ,
Nov 08, 2010 Nov 08, 2010
I have searched for a complete example on how to use JQuery and CFML to submit a form.
So how to submit a form, pass it's form values to the data page and return it all to the page where the form is on.
I found all kinds of different code snippets but no complete example, can anyone help me, provide such?
Thanks!
TOPICS
Advanced techniques
Views
2.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged , Nov 08, 2010 Nov 08, 2010
Does this help?
http://www.coldfusionjedi.com/index.cfm/2010/5/8/Simple-jQueryColdFusion-form-example
Votes
Translate
Translate
Engaged ,
Does this help?
Votes
Translate
Translate
Report
Report
Participant ,
That is very helpfull :), only problem, even if i log in with the given username and password i keep getting login failed, your example on your page works fine...
Maybe it's because i am using Railo, can't think of anything else, using the same code, same browser.
Votes
Translate
Translate
Report
Report
Engaged ,
Well, I'd recommend adding some logging. In your CFC, log the
arguments sent. Also check to see what Firebug is showing you.
Votes
Translate
Translate
Report
Report
Participant ,
I am not sure how to check on the argument being send in:
component {
    remote boolean function authenticate(string username, string password) {
        sleep(1400);
        if(arguments.username == "paris" && arguments.password == "hilton") return true;
        return false;
I am not used to work with script cfc's
Votes
Translate
Translate
Report
Report
Engaged ,
Well, one option is to rewrite it in tag based language.
But here is a quick log:
writeLog(file="application", text="#serializejson(arguments)#");
This writes to the application log. It writes a JSON version of the arguments.
Votes
Translate
Translate
Report
Report
Participant ,
I am trying the first option but haven't got any luck:
<cfcomponent>
    <cffunction name="authenticate" access="remote" returntype="boolean">
        <cfargument name="username" type="string" required="yes">
        <cfargument name="password" type="string" required="yes">
        <cfdump var="#argument.username#">
        <cfabort>
        <cfif argument.username eq "paris" and argument.password eq "hilton">
        <cfreturn true>
        <cfelse>
        <cfreturn false>
        </cfif>
    </cffunction>
</cfcomponent>
Votes
Translate
Translate
Report
Report
Engaged ,
Ok, so what does Firebug show you?
Votes
Translate
Translate
Report
Report
Participant ,
Emmm i was hoping that the cfdump would work as i don't really understand how to use firebug to check on what's going on.
Votes
Translate
Translate
Report
Report
Engaged ,
Knowing how to use Firebug for Ajax is critical. Seriously. Check this
video. It walks you through the process:
http://insideria.com/2009/06/quick-video-example-of-firebug.html
Votes
Translate
Translate
Report
Report
Participant ,
That is awesome so now i know what to do with firebug!
I tested with firebug and i get a respons of false when the login is wrong and a respons of true when the login is correct.
So the cfc is working correctly.... strange.......
<cfcomponent>
        <cfif arguments.username eq "paris" and arguments.password eq "hilton">
        <cfreturn true>
        <cfelse>
        <cfreturn false>
        </cfif>
    </cffunction>
</cfcomponent>
Votes
Translate
Translate
Report
Report
Engaged ,
So then your front end code isn't working - can you show that?
Votes
Translate
Translate
Report
Report
Participant ,
Yes here it is, saved in a file called jqueryajax2.cfm:
<html>
<head>
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script>
$(document).ready(function() {
    //grab the submit action
    $("#loginForm").submit(function(e) {
        //stop the form submission
        e.preventDefault()
        //get my values
        var uval = $("#username").val()
        var pval = $("#password").val()
        //basic validation
        if(uval == '' || pval == '') return
        //disable the button
        $("#loginButton").attr("disabled",true)
        //Let the user know we are doing something
        $("#result").html("Logging in...")
        //Send them to the CFC
        $.post("test.cfc?method=authenticate&returnformat=json",
                {username:uval, password:pval},
                function(res) {
                    //Handle the result
                    if(res == "true") {
                        $("#result").html("Your login worked.")
                        //Do more here.
                    } else {
                        $("#result").html("Your login failed.")
                        $("#loginButton").removeAttr("disabled")
</script>
</head>
<body>
<form id="loginForm">
    username: <input type="text" name="username" id="username"><br/>
    password: <input type="password" name="password" id="password"><br/>
    <input type="submit" value="Login" id="loginButton">
</form>
<div id="result"></div>
</body>
</html>
Votes
Translate
Translate
Report
Report
Engaged ,
So after
function(res) {
add
alert(res);
or console.log(res)
And tell us what you see.
Oh- nevermind. It's whitespace. I can gaurantee it. Either add
output=false to your cfcomponent AND cffunction tag, OR do this
res =$.trim(res);
$.trim() is a jquery function.
Votes
Translate
Translate
Report
Report
Participant ,
Ahhh yes! That was the problem, perfect, thanks for your time, learned a bit more!
Votes
Translate
Translate
Report
Report
Participant ,
Nov 09, 2010 Nov 09, 2010
So now the question is how to change:
//Handle the result
                    if(res == "true") {
                        //Do more here.
                    } else {
So it will catch and display a query result set that i can set in the .cfc.
What would be the change when i have for example a query returned named "results".
Any idea's?
Votes
Translate
Translate
Report
Report
Engaged ,
Would you mind if I did this in a blog entry today? So I have a bit
more space (and yeah, traffic .
Votes
Translate
Translate
Report
Report
Participant ,
That would be awesome!
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
http://www.coldfusionjedi.com/index.cfm/2010/11/9/Working-with-a-ColdFusion-Query-in-jQuery
Votes
Translate
Translate
Report
Report
Resources
Documentation
