1 Reply Latest reply on Nov 8, 2010 12:24 PM by jeffcg2
    PHP configuration problems
    jeffcg2 Level 1
      I'm making another run at getting Flash Builder to work with PHP. This weekend I finally got Flash Builder to work with PHP on my Windows 7 64 bit machine. By configuring IIS7 for Zend. I got a nice nice photo gallery working with a WheelLayout on my PC with an data service pulling data from a MySQL DB on my hosting server.
      Then I created the release build and posted it to my hosting server. After getting a plethora of errors(Google is my friend), I uploaded the Zendframework and made a couple of changes and voila the gateway.php works. I would expect something to be showing up in the LodgeService.php file but I get a blank page. I uploaded the bin and bin-debug directories and both give me the same result a popup in the middle of the screen that just says OK. and a message that says it is Transferring data.
      I assume it is a problem with the programmer, but I don't know where to go from here to troubleshoot.
      http://charlestonlodge35.com/bin-debug/zend.html
      http://charlestonlodge35.com/bin/zend.html
      http://charlestonlodge35.com/bin/gateway.php
      http://charlestonlodge35.com/bin/services/LodgeService.php
        • 1. Re: PHP configuration problems
          jeffcg2 Level 1
          Ok progress
          In case I'm not the only one to have this beginner problem.
          2 simple changes in the amf_config file
          1) changing amf.production = false stops suppressing the error messages so I could see the error.
          2) Changed amf_config from amf.directories[]=zend/bin/services to bin/services.
          ERROR
          Class "LodgeService" does not exist: Plugin by name 'LodgeService' was not found in the registry; used paths:
          : ..//zend/bin-debug/services/
          [zend]
          ;set the absolute location path of webroot directory, example:
          ;Windows: C:\apache\www
          ;MAC/UNIX: /user/apache/www
          webroot =../
          ;set the absolute location path of zend installation directory, example:
          ;Windows: C:\apache\PHPFrameworks\ZendFramework\library
          ;MAC/UNIX: /user/apache/PHPFrameworks/ZendFramework/library
          ;zend_path =
          [zendamf]
          amf.production = true
          amf.directories[]=bin/services
