3 Replies Latest reply on Nov 9, 2010 7:45 AM by tehxike1
    factory items fail is Class test
    tehxike1 Level 1
      I have a factory defined in my skin file:
      <fx:Component id="radioButtonClass">
           <s:RadioButton />
      </fx:Component>
      I use this in my code:
      metaComp = radioButtonClass.newInstance();
      I later iterate over the items, attempting to perform actions on them based on their type:
      case ToggleButtonBase:
           //do stuff
           break;
      But every item shows up as the radioButtonClass.generator:
      com.levelsbeyond.search.skins.SearchPropertiesViewSkinInnerClass7 (@88f10a1)
      How can I do a class test against the object?  I'm trying this, but it doesn't work either:
      case (radioButtonClass as ClassFactory).generator:
      I'd love to be able to just check to see if something's a ToggleButtonBase, but that doesn't pass the is test.
        • 1. Re: factory items fail is Class test
          Shongrunden Adobe Employee
          Can you use className instead of id?  This seems to work:
                         creationComplete="init()">
              <fx:Script>
                  <![CDATA[
                      import spark.components.RadioButton;
                      private function init():void{
                          var myComponent:MyComponent = new MyComponent();
                          if (myComponent is RadioButton)
                              test.text = 'pass';
                          else
                              test.text = 'fail';
              </fx:Script>
              <fx:Declarations>
                  <fx:Component className="MyComponent">
                      <s:RadioButton/>
                  </fx:Component>
              </fx:Declarations>
              <s:Label id="test" />
          </s:Application>
          • 2. Re: factory items fail is Class test
            Actually it looks like using id works as well:
                <fx:Script>
                    <![CDATA[
                        import spark.components.supportClasses.ToggleButtonBase;
                            var myComponent:Object = MyComponent.newInstance();
                            if (myComponent is ToggleButtonBase)
                                test.text = 'pass';
                            else
                                test.text = 'fail';
                </fx:Script>
                <fx:Declarations>
                    <fx:Component id="MyComponent">
                        <s:RadioButton/>
                    </fx:Component>
                </fx:Declarations>
            </s:Application>
            • 3. Re: factory items fail is Class test
              tehxike1 Level 1
              Ah yeah, the is check is working for me too.  I'm not sure why it doesn't pass in the switch, but this will work fine.  Thanks
