1 Reply Latest reply on Nov 8, 2010 3:41 PM by SashaKeith
    Filtering data
    GeorgeWS Level 1
      I have a datagrid filled from an ArrayCollection. I have a combo
      box I want to use to filter the data. like:
      public function processFilter(item:Object):Boolean
      var result:Boolean=false;
      if(item.YDSPNO == brandfilter2.selectedItem.data)
      result=
      true;
      return result;
      Filtering works great I pick something from the combobox and the data in the datagrid gets filtered:
      [Bindable] private var newSupplier:ArrayCollection=new ArrayCollection;
      public function doPrompt2( event:ResultEvent ):void {
      newSupplier = Suppliers2.Suppliers2.lastResult;
      var prompt:Object = new Object();
      prompt.data =
      null;
      prompt.label =
      "Select Supplier";
      newSupplier.addItemAt( prompt, 0 );
      brandfilter2.selectedIndex = 0;
      <mx:ComboBox
      id="brandfilter2" dataProvider="{newSupplier}" labelField="label" width="200" change="myBrand.refresh()" height="35" fontSize="15" includeInLayout="false" visible="false" close="selectedItem=ComboBox(event.target).selectedItem"/>
      My issue is that when I put the combobox back to "select Supplier" it does not reset to the full data set. I have other senarios just like this and they work fine. STUMPED
      George
