2 Replies Latest reply: Nov 9, 2010 7:30 AM by cj_mcmillen RSS
    CS5 page curl direction/speed
    cj_mcmillen Community Member
      No matter what I try, I can't seem to activate the page curl options (direction or speed) after I apply the "Page Turn" feature (to the first page, no other animations on it) from within InDesign. I know I can also have a page curl via the export function, but I don't see any options to change the direction there, either.
      What am I doing wrong?
        • 1. Re: CS5 page curl direction/speed
          [Jongware] Community Member
          I know I can also have a page curl via the export function ..
          That's the only way to get the curl.
          You cannot adjust anything because there are no options to change. To get a specific effect, you might try editing the SWF manually.
          (On reading the Help it seems to me there are two "different" Page Curls; the one you select in the Transition panel, and another one in the SWF Export. Perhaps you need "the other one".)
          • 2. Re: CS5 page curl direction/speed
            But the Direction and Speed options are there under the Transitions drop-down menu. I'm 'assuming' both should be able to be applied to the Page Curl option because I saw an example that had the page turning from the top right corner, not bottom.
            (Yes, I'm looking at the Page Transitions method for this, not upon export to SWF.)
