1 Reply Latest reply on Nov 9, 2010 3:08 AM by celebritymusic
    Listing a subdir's contents?
    celebritymusic Level 1
      Hi
      I'm wondering how to change the following code so that I get a listing of files in a folder called 'tester' that resides in the
      documentsDirectory?
      var directory:File = File.documentsDirectory;
      directory.getDirectoryListingAsync();
      directory.addEventListener(FileListEvent.DIRECTORY_LISTING, directoryListingHandler);
      function directoryListingHandler(event:FileListEvent):void {
      var list:Array = event.files;
      for (var i:uint = 0; i < list.length; i++) {
      trace(list[i].nativePath);
      I found another set of code that's close, but I still can't get it to work?
      Is there a simple way to add /tester to the abvove code?
      var fileList = new Array();
      function getFilesRecursive(folder) {
      //the current folder object
      var currentFolder = new File(folder);
      //the current folder's file listing
      var files = currentFolder.getDirectoryListing();
      //iterate and put files in the result and process the sub folders recursively
      for (var f = 0; f < files.length; f++) {
      if (files[f].isDirectory) {
      if (files[f].name !="." && files[f].name !="..") {
      //it's a directory
      getFilesRecursive(files[f].nativePath);
      } else {
      //it's a file yupeee
      fileList.push(files[f].nativePath);
        • 1. Re: Listing a subdir's contents?
          OK - for anyone that may need it - I played a bit and got it to work:
          var mediaDirList:File = File.documentsDirectory;
          mediaDirList = mediaDirList.resolvePath("tester/");
          mediaDirList.getDirectoryListingAsync();
          mediaDirList.addEventListener(FileListEvent.DIRECTORY_LISTING, directoryListingHandler);
          This seems WAYYY simpler than some of the solutions I looked at, so I'm wondering if it's best practice - it would work cross platform, right?
          Thanks (forgot my manners in the last post).
          Shaun
