1 Reply Latest reply on Nov 9, 2010 2:56 PM by SrinivasAnnam
    Scaling project constraint - Minimal with and height of movie
    danielcote
      I'm using scaling contraint for components inside my panini project, but I want the whole Flash to stop scaling below a certain width and height of the movie.
      The best way to understand this is to go to the HBO website:
      http://www.hbo.com
      (Play with the width and height of the browser window and you will see at a certain point, the movie stop scaling and a browser scrolling appear.)
      Also, if you go to a page with more vertical content (click on 'video' link on top) you see a Flash scolling component appear at the right.
      I was wondering how to duplicate these behavior?
      Inside Panini setting, publish settings, Flex code ?
      Here is the html source for the flash call on HBO website using the swfobject:
      function renderFlash()
                  var flashvars = {configDir: "/config/prod/"};
                  var params = {wmode:'opaque', align:'top', scale:'noscale', bgcolor:'#000000', allowFullScreen:'true', allowScriptAccess:'sameDomain', base:'web'};
              var attributes = {id: 'myContent',name:'myContent'};
              swfobject.embedSWF("/bin/siteMain.swf", "pageContent", "100%", "100%", "9.0.124", "utils/flash/expressInstall.swf", flashvars, params, attributes);
             // if (!swfobject.hasFlashPlayerVersion("9.0.124"))
             //     window.location = '/html/error/browser_error.html';
              JQ(".spacer").css("display", "none");
      Thanks to all
        • 1. Re: Scaling project constraint - Minimal with and height of movie
          SrinivasAnnam Adobe Employee
              You can set "minWidth" & "minHeight" properties at Application level (first tag of Main.mxml) to desired value to achieve this.
              You will need to open your FXP file in FlashBuilder (File->Import Flash Builder project) to do this modification.
              Here is an example.
                             xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx"
                             minWidth="600" minHeight="400">
          Regards
          Srinivas Annam
