5 Replies Latest reply on Aug 10, 2011 4:06 AM by Balakrishnan V
    Flex Mobile : URLLoader bytesTotal always at 0 when loading file
    VinceDDH
      Hi !
      I'm trying to load external file with UrlLoader in a Flex Mobile Project ( Initialy it was with Data/Services Options of Flash Builder, but I have the same problem ). On the complete event, it work on the desktop ( bytesTotal, xml... ), but when i install my application on my nexus one ( air version : 2.5.0.1660 ), i've no data ( bytesTotal = 0 ), but the cache of the application has grown
      The application has these autorisations :
                  <uses-permission android:name="android.permission.INTERNET"/>
                  <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"/>
                  <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
      If someone can help me...
      Thx !
      Vince
        • 1. Re: Flex Mobile : URLLoader bytesTotal always at 0 when loading file
          Mr Draust
          Did you find a solution for this?
          Ive got a very simular problem when i run a app on a device, it receieves no data.
          • 2. Re: Flex Mobile : URLLoader bytesTotal always at 0 when loading file
            Rangora Level 3
            Where is the file you try to load? I think you cannot access the private app install directory with the URLLoader.
            • 3. Re: Flex Mobile : URLLoader bytesTotal always at 0 when loading file
              Mr Draust Level 1
              Its an external file, located on a server.
              To be precise, im doing a post message to an obix server. Suppose to get back information/data in xml, but its not working.
              • 4. Re: Flex Mobile : URLLoader bytesTotal always at 0 when loading file
                irongamer Level 1
                After messing with the URLLoader for a native windows AIR app I gave up on it. That object will return 200, ok, complete, while failing to do what it says it did.
                I never found any way to catch a real error from the server with any of the event listeners for URLLoader.  Instead I used HTTPService, it acutally returns useful data on server errors.  Here is an example, all this is tucked into my own class.
                var service:HTTPService = new HTTPService();
                               service.url = url;
                               service.resultFormat = HTTPService.RESULT_FORMAT_E4X;
                               service.method = URLRequestMethod.POST;
                               service.addEventListener(ResultEvent.RESULT,serviceResult);
                               service.addEventListener(FaultEvent.FAULT,faultResult);
                               service.send(vars);
                private function serviceResult(eResult:ResultEvent):void
                               var objResult:Object = eResult;
                               if( objResult.result is XML )
                                    xmlData = eResult.result as XML;
                                    trace(xmlData);
                                    dispatchEvent( new Event('eComplete') );
                               else
                                    //something wrong
                                    trace('BAD! No XML Returned: '+eResult.result);
                                    dispatchEvent( new Event('eError') );
                private function faultResult(e:Event):void
                               if( e is ErrorEvent )
                                    trace( ErrorEvent(e).text );
                               else if ( e is FaultEvent )
                                    trace( FaultEvent(e).message.toString() );
                               else
                                    trace( 'Unhandled error' );
