0 Replies Latest reply on Nov 9, 2010 10:21 AM by Julian Hirjoi
    OptionalDataException causing Assign Task to stall
    Julian Hirjoi
      I have an awkward issue when updating an application lca in LiveCycle. Although everything is currently cleaned up, so no instances of the previous application version are running when the new lca is imported, i get an exception in the logs, java.io.OptionalDataException, and all assigned tasks are stalled. What is even stranger, is if I turn on recording on the process containing the AssignTask and start another instance of the process, everything works correctly, no stalled actions...
      Has anybody experienced this issue? Any help would be highly appreciated...
      Exception stack trace:
      java.io.OptionalDataException: java.lang.RuntimeException: java.io.OptionalDataException
                  at com.adobe.idp.jobmanager.execution.InternalJobManager.deserializeObject(InternalJobManage r.java:1368)
                  at com.adobe.idp.jobmanager.execution.InternalJobManager.createJob(InternalJobManager.java:1 04)
                  at com.adobe.idp.jobmanager.service.JobManagerService.createJob(JobManagerService.java:82)
                  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                  at java.lang.reflect.Method.invoke(Method.java:585)
                  at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
                  at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
                  at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
                  at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
                  at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
                  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:357)
                  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:227)
                  at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_ caf58c4f.doSupports(Unknown Source)
                  at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:104)
                  at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
                  at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
                  at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
                  at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:165)
                  at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
                  at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
                  at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:121)
                  at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:93)
                  at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:22 5)
                  at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:66)
                  at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
                  at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:861)
                  at com.adobe.workflow.engine.SynchronousBranch.handleInvokeAction(SynchronousBranch.java:510 )
                  at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:888)
                  at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBea n.java:2797)
                  at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncInvokeProcessCommand(ProcessEngineBMT Bean.java:697)
                  at com.adobe.workflow.engine.EJSLocalStatelessadobe_ProcessEngineBMTEJB_7d3cbd67.asyncInvoke ProcessCommand(Unknown Source)
                  at com.adobe.idp.workflow.dsc.service.ProcessCommandExecutorService.invokeProcess(ProcessCom mandExecutorService.java:55)
                  at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:154)
                  at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
                  at com.adobe.workflow.engine.PEInvokeProcessCommand.execute(PEInvokeProcessCommand.java:126)
                  at com.adobe.workflow.workadapter.WorkflowCommandExecutionUnit.execute(WorkflowCommandExecut ionUnit.java:22)
                  at com.adobe.idp.dsc.workmanager.adapter.ManagedAsynchronousWorkAdapter.run(ManagedAsynchron ousWorkAdapter.java:70)
                  at com.adobe.idp.dsc.workmanager.adapter.websphere.J2WA_Work.run(J2WA_Work.java:34)
                  at com.ibm.ws.asynchbeans.J2EEContext$RunProxy.run(J2EEContext.java:261)
                  at java.security.AccessController.doPrivileged(Native Method)
                  at javax.security.auth.Subject.doAs(Subject.java:337)
                  at com.ibm.websphere.security.auth.WSSubject.doAs(WSSubject.java:118)
                  at com.ibm.ws.asynchbeans.J2EEContext$DoAsProxy.run(J2EEContext.java:328)
                  at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:757)
                  at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecutionContextImpl.java: 218)
                  at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:158)
                  at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1497)
      Caused by: java.io.OptionalDataException
                  at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1325)
                  at java.io.ObjectInputStream.readObject(ObjectInputStream.java:348)
                  at java.util.HashMap.readObject(HashMap.java:1066)
                  at sun.reflect.GeneratedMethodAccessor15.invoke(Unknown Source)
                  at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:946)
                  at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1809)
                  at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1719)
                  at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1305)
                  at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1908)
                  at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1832)
                  at java.util.ArrayList.readObject(ArrayList.java:591)
                  at sun.reflect.GeneratedMethodAccessor282.invoke(Unknown Source)
                  at java.io.ObjectInputStream.defaultReadObject(ObjectInputStream.java:479)
                  at com.adobe.workflow.pat.service.PATExecutionContextImpl.readObject(PATExecutionContextImpl .java:1383)
                  at java.util.HashMap.readObject(HashMap.java:1067)
                  at com.adobe.idp.jobmanager.execution.InternalJobManager.deserializeObject(InternalJobManage r.java:1348)
                  ... 84 more
