6 Replies Latest reply on Nov 18, 2010 4:48 PM by Peter Kahrel
    Get all image dimensions and apply to other document
      InDesign CS3 on a MacBook Pro running Snow Leopard
      Hi ppl,
      I have the following problem:
      I have two identical documents - well they are identical in the sense that they have the exact same layout plus number and placement of graphic and text frames. Only the image dimensions of the graphic files in the graphic frames of on of the two documents are different.
      I am trying to find a script that reads the dimensions of the graphics in every graphic frame from one document and applies these dimensions to the same graphic in the according graphic frame of the other document.
      Since both files are built exactly the same way it should work with simply working down an array which was filled first with the graphic dimensions of the source file.
      Unfortunately I do not have the knowlegde to make it happen...
      Any help is highly appreciated!
      Thanks a million!
