0 Replies Latest reply on Nov 9, 2010 1:15 PM by zhijiang@chen.me
    Problem with Adobe AIR Offline sync with ColdFusion server
      I having problem to sync with local and remote db, environment.
      - Flex Hero.
      - Coldfusion 9.0
      - MySql 5
      The GlobalVars follow same as http://www.adobe.com/devnet/coldfusion/articles/offline_air_orm.html.
      The problem is when I create a user (entity at both size), it can be stored in local db without problem, but the session.save(obj) process didn't trigger commit to remote server (ColdFusion), (SyncManager.autocommit = ture), I tried set AutoCommit = false then use session.commit() to manually commit it, it didn't work neither.
      Anyone have same problem?
      Thanks in advance.
      GlobalVars.as (part):
      //public static var syncmanager:SyncManager = new SyncManager();
                public static var Port:int=8500;
                public static var Server:String="localhost";
                public static var serverCFC:String = "DonkeyTravel.services.cusManager";
                public static var CurrentPage:String;
                public static var dbFile:File =File.userDirectory.resolvePath("CustomerManager.db");
                public static var dbDir:File;
                public static var CacheInt:int = 1;
                public static var Online:Boolean = false;
                public static var OnlineImage:String = "/assets/ball-32.png";
                public static var OfflineImage:String = "/assets/ballred-32.png";
                public static var Changes_present:String = "/assets/32TRUE.png";
                public static var On_Off_Image:String;
                public static var productListComboItems:ArrayCollection = new ArrayCollection();
                public static var CustomerListComboItems:ArrayCollection = new ArrayCollection();
                public static var myTimer:Timer = new Timer(15000);
                myTimer.addEventListener(TimerEvent.TIMER, timerHandler);
                public static var syncManager:SyncManager;
                public static var session:Session;
                public static var PROD_CONFLICT_RESOLVED:String = "prodConflictResolved";
                public static var ORDER_CONFLICT_RESOLVED:String = "orderConflictResolved";
                public static var CUST_CONFLICT_RESOLVED:String = "custConflictResolved";
                public static var evtDisptchr:EventDispatcher = new EventDispatcher();
                public static function init():void
                     var logTarget:TraceTarget = new TraceTarget();
                     logTarget.level= LogEventLevel.ALL;
                     // Provide Credentials for Server side Connection and CFC
                     syncManager = new SyncManager();
                     syncManager.autoCommit = true;
                     syncManager.cfPort = Port;
                     syncManager.cfServer = Server;
                     // Path of the Server side CFC having Sync/Fetch method, relative from CF webroot
                     syncManager.syncCFC = serverCFC;
                     // THis handler will be called when any COnflict occures while writing back changes on serverside
                     syncManager.addEventListener(ConflictEvent.CONFLICT, conflictHandler);
