I just upgraded our server from 8.2 to ES2 SP2. I had several active process instances before the upgrade that I'm testing post upgrade.
The process I'm testing uses a Query Single Row Operation which is stalling. It's stalling because I don't have a required parameter(Data Mapping) defined. This parameter was not required in 8.2 so it worked fine.
So I fixed that issue with the process(after creating an application and importing the process), and attempted a retry on the process, but that is not working. Livecycle continues to use the invalid version of the process that does not specify the required parameter when I attempt a retry.
So, my question is how can I update the "active" version of the upgraded process and retry the stalled process instances?
Views
Total Likes
The "deploy" option in the application version menu is apparently what I was looking for.
Views
Total Likes
