2 Replies Latest reply on Nov 18, 2010 2:16 PM by Hasan Otuome
    Native Menu behavior on Mac
    dkelly60
      Why does the Mac add extra File, Edit and Window menu items to programs?
      To see an example run the example for using native windows found here
      http://help.adobe.com/en_US/as3/dev/WS5b3ccc516d4fbf351e63e3d118666ade46-7de7.html
      You end up with
      ProgramName - File - Edit - Window - File - Edit
      instead of
      In the example the last File and Edit are the menus for the program.
        • 1. Re: Native Menu behavior on Mac
          Joe ... Ward Level 4
          Those are the default menu items that you always get. The example should either replace the default submenus, or add the new commands to the existing submenus.
          • 2. Re: Native Menu behavior on Mac
            Hasan Otuome
            Here's an example of modifying the existing menu items and adding an additional menu item for OSX:
            // generate native menu for OSX
            if (NativeApplication.supportsMenu)
            nativeMenu = NativeApplication.nativeApplication.menu;
            fileMenu = nativeMenu.getItemAt( 1 );
            fileMenu.submenu.removeAllItems();
            fileMenu.submenu = _generateFileMenu();
            editMenu = nativeMenu.getItemAt( 2 );
            editMenu.submenu.removeAllItems();
            editMenu.submenu = _generateEditMenu();
            exportMenu = nativeMenu.getItemAt( 3 );
            helpMenu = nativeMenu.addItem( new NativeMenuItem(HELP) );
            helpMenu.submenu = _generateHelpMenu();
            To modify the root menu item just get the item @ 0 since it's 0-based...
