2 Replies Latest reply on Nov 10, 2010 9:14 AM by azathoth_
    XML iteration trouble
    azathoth_
      Hello all
      In my orchestration I have a xml variable like this:
      <form>
          <routes>
              <route>
                  <elements>
                      <foo>xxx</foo>
                      <foo>yyy</foo>
                      <foo>zzz</foo>
                  </elements>
                  <elements>
                      <foo>ee</foo>
                      <foo>ii</foo>
                      <foo>kk</foo>
                      <foo>aa</foo>
                  </elements>
              </route>
              <route>
                  <elements>
                      <foo>xxx</foo>
                  </elements>
                  <elements>
                      <foo>ff</foo>
                      <foo>mmm</foo>
                  </elements>
              </route>
          </routes>
      </form>
      I use a setValue/decisionPoint combination to iterate through it, first of all I get the routes count with an xPath and start a counter like this:
      /process_data/@routesCount = count(/process_data/xmlVar/routes/route)
      /process_data/@routesCounter = /process_data/@routesCounter +1
      Then I go on to iterate inside that routes/route[1] node using the same method, I want to get the number of 'foo' elements inside route[1] so I have the setValue:
      /process_data/@fooCount = count(/process_data/xmlVar/routes/route[/process_data/@routesCounter]/elements/foo)
      but I'm getting the total foo count of the entire document (10) instead of 3
      I have done recording/playback several times, the @routesCount and @routesCounter index work fine, but I always get 10 for the @fooCount.
      When I execute the XPath query:
      count(/form/routes/route[1]/elements/foo)
      in Oxygen I get 3 for a result
      Somehow LC is not taking the @routesCounter index into consideration when querying the XML
      Have you tried to do this double-iteration stuff?
      Thanks for your help
