2 Replies Latest reply on Jul 15, 2007 3:30 PM by JingZhe SHAN
    Transfer an XML to Array to make a menu bar's dataProvider.
    JingZhe SHAN
      Hi All:
      Currently there is an XML variable transferred to the Flex application, which used to build the menuBar's data provider.
      And the structure of this XML variable may change dynamicly but will restricly follow the this pattern
      eg:
      <menuitems>
      ------<menuitem/>
      ------<menuitem>
      ------------<menuitems/>
      ------</menuitem>
      <menuitems>
      [Bindable]
      public var menuDataXML:XML =
      <menuitems>
      <menuitem label="menu2">
      <menuitems >
      <menuitem data="app1" label="ACS">
      <menuitems/>
      </menuitem>
      <menuitem data="app2" label="app2">
      <menuitems/>
      </menuitem>
      <menuitem label="menu3">
      <menuitems>
      <menuitem data="app4" label="app4">
      <menuitems/>
      </menuitem>
      <menuitem data="app3" label="app3">
      <menuitems/>
      </menuitem>
      </menuitems>
      </menuitem>
      </menuitems>
      </menuitem>
      </menuitems>;
      This XML looks like
      menu2----ACS
      )))))))))----app2
      )))))))))----menu3 ----app3
      ))))))))))))))))))))))) ----app4
      Before I use this as the menuBar's dataProvider I need make some modifications. I have to build a Array to store this XML info.
      Is there have a robust way to do this? Thanks
        • 1. Re: Transfer an XML to Array to make a menu bar's dataProvider.
          RichardHz
          You could try the following;
          mxml extract:
          <mx:MenuBar id="mainMenu"/>
          <mx:HTTPService id = "menuXml"
          url = "Assets/MenuData.xml"
          result="menuXmlHandler(event)"
          resultFormat="e4x"/>
          Then some action script:
          [Bindable]
          private var xmlData:XMLList;
          private function menuXmlHandler(event:ResultEvent):void
          var result:XML = event.result as XML;
          xmlData = result.menu;
          mainMenu.dataProvider = xmlData;
          mainMenu.labelField ="@label";
          The xml would look like;
          <MyMenu>
          <menu label="Item1" data="top">
          <submenu label= "sub item1" data= "xxx" />
          <submenu label= "sub item2" data= "yyy" />
          <submenu label= "sub item3" data= "zzz" />
          </menu>
          <menu label="Item2" data="top">
          <submenu label= "sub item a" data= "xx1" />
          <submenu label= "sub item b" data= "xx2" />
          <submenu label= "sub item c" data= "xx3" />
          </menu>
          </MyMenu>
          The above uses an XMLList type instead of an array . The menu structure is then defined by the xml, change the xml and the menu changes.
          Hope this helps
          Richard HZ
          • 2. Re: Transfer an XML to Array to make a menu bar's dataProvider.
            JingZhe SHAN Level 1
            Thanks Richard HZ. I have problem to build the correct XML format to fit for the menu's data source.
