10 Replies Latest reply on Nov 10, 2010 2:05 PM by WheatWilliams
    Newbie--AppleScript for InDesign CS5 help needed
    WheatWilliams
      How can I select a page number in a table (a text string as a Source) and have an AppleScript read that text string and convert it to an integer value?
      I have to put over 1,200 hyperlinks into a document that already has page numbers in tables. Each page number (Source) will be assigned a hyperlink to go to that page (Destination).
      The page numbers in tables are in the preface to my document, which is 44 pages in length.
      The actual pages in the main body of my document are numbered 1-432. Thus, the 45th page in the document is Page 1 to the person reading it, and the 476th page is Page 432.
      So if a table in my preface has a page number of 32, for instance, the actual page number I want as a Destination is 32 + 44, or page 76.
      If I manually double-click to select the text of a number "x" in a table as a Source, I want to write a script that when invoked will
      read the text string I have selected
      convert it to an integer value equal to the number in the text string
      add 44 to that value
      create a hyperlink that goes to the destination page number that corresponds to that value
      Thanks.
        • 1. Re: Newbie--AppleScript for InDesign CS5 help needed
          Muppet Mark-QAl63s Level 4
          I don't have CS5 but you could give this a try just to get you going…
          tell application "Adobe InDesign CS2"
          tell the active document
          set selected to selection
          if (count of selected) = 0 then
          display dialog "No Selection?" giving up after 2
          else
          try
          set destPage to (every text of selection) as integer
          set destPage to destPage + 44
          display dialog "Destination Page: " & destPage giving up after 2
          on error
          display dialog "Selected text was NOT coerced to number?" giving up after 2
          end try
          end if
          end tell
          end tell
          • 2. Re: Newbie--AppleScript for InDesign CS5 help needed
            WheatWilliams Level 1
            I can't get AppleScript and InDesign CS5 to recognize
            make new hyperlink
            or
            make hyperlink
            So what should the command and class be called? I can't find any documentation.
            • 3. Re: Newbie--AppleScript for InDesign CS5 help needed
              Here's my attempt:
              tell application "Adobe InDesign CS5"
              set mySelection to selection
              set myNumber to (mySelection as integer)
              set myNumber to myNumber + 44
              make new hyperlink with properties {page:myNumber, zoom setting:fixed, visible:true, width:thin, border color:blue, style:solid}
              end tell
              But this isn't working. The error message is "Can't make class hyperlink".
              I don't want a new hyperlink with a URL; I want a hyperlink with page number.
              If you manually open the New Hyperlink dialog box, the first field needs to say Link To:Page, "Page" being selected from the pull-down menu.
              So what should my correct syntax be?
              • 4. Re: Newbie--AppleScript for InDesign CS5 help needed
                I think you will first need to…
                set hpdest to make new hyperlink page destination with properties ¬
                {Blah, Blah, Blah}
                then pass that to your make hyperlink…
                • 5. Re: Newbie--AppleScript for InDesign CS5 help needed
                  Not quite there yet.
                  I did as you suggested but whatever I do it returns:
                  "error "Adobe InDesign CS5 got an error: Can’t make class hyperlink page destination." number -2710 from hyperlink page destination to class"
                  or
                  "error "Adobe InDesign CS5 got an error: Can’t make class hyperlink." number -2710 from hyperlink to class"
                  Is there something about InDesign CS5 that is different from CS4 with regards to what this class is supposed to be named? Again, I can find no documentation.
                  Your help is much appreciated.
                  This is a tiny script that is needed for a big, time-consuming job, and I would be willing to pay somebody to write the script for me offline if you can guarantee you'll keep at it until it works.
                  This is my first time writing an AppleScript!
                  • 6. Re: Newbie--AppleScript for InDesign CS5 help needed
                    Maybe I should get somebody good at JavaScript if that's better documented?
                    • 7. Re: Newbie--AppleScript for InDesign CS5 help needed
                      Olav Martin Kvern Level 3
                      Hi WheatWilliams,
                      It's partly a problem of your tell context. In your example, telling the InDesign application to make a hyperlink. That won't work--you need to tell the document to make the hyperlink (as in Muppet Mark's example--thanks for pitching in, Muppet Mark!).
                      Here's a really basic example:
                      set myDocument to make document
                      tell myDocument
                      set horizontal measurement units of view preferences to points
                      set vertical measurement units of view preferences to points
                      set myTextFrame to make text frame with properties {geometric bounds:{72, 72, 144, 288}, contents:"Hyperlink destination"}
                      set myText to object reference of text 1 of parent story of myTextFrame
                      set myHyperlinkTextDestination to make hyperlink text destination with properties {destination text:myText}
                      set myTextFrame to make text frame with properties {geometric bounds:{288, 72, 432, 288}, contents:"Hyperlink source"}
                      set myHyperlinkTextSource to make hyperlink text source with properties {source text:myText}
                      set myHyperlink to make hyperlink with properties {source:myHyperlinkTextSource, destination:myHyperlinkTextDestination}
                      end tell
                      end tell
                      Ole
                      • 8. Re: Newbie--AppleScript for InDesign CS5 help needed
                        Thanks guys. It's clear that I am in over my head here.
                        I mean no disrespect, but I do not need to learn how to write AppleScript.
                        I need to pay somebody to write one simple AppleScript for me so I can finish a huge project on a deadline.
                        And I don't understand your reference to making a new document in InDesign. I already have a 500-page document full of text, and full of tables of numbers that I need to attach hyperlinks to. There are many tables and many pages all formatted somewhat differently, with several different kinds of columns of numbers. What I want is a "macro" where I can select something with my mouse, invoke the script, and have the proper information filled in for that one number only.
                        Can someone step in and let me hire him or her to solve this problem?
                        • 9. Re: Newbie--AppleScript for InDesign CS5 help needed
                          Hi WheatWilliams,
                          Something like this, then:
                          set myTextObjects to {text, character, word, text style range, line, paragraph, text column, cell, table, row, column}
                          if (count documents) is greater than 0 then
                          if (count mySelection) is equal to 1 then
                          tell document 1
                          --Is the selection a text selection?
                          if class of item 1 of mySelection is in myTextObjects then
                          set myText to item 1 of mySelection
                          try
                          set myErrorString to "Selection already contains a hyperlink text source."
                          --Create the hyperlink text source.
                          set myPageNumber to item 1 of mySelection as integer
                          set myPageNumber to myPageNumber + 44
                          set myErrorString to "Could not get page number."
                          set myPage to page myPageNumber
                          set myErrorString to "Could not create hyperlink page destination."
                          --Create they hyperlink page destination.
                          set myHyperlinkPageDestination to make hyperlink page destination with properties {destination page:myPage}
                          set view percentage of myHyperlinkPageDestination to 100
                          --Now use the source and the destination to create the hyperlink.
                          set myErrorString to "Could not create hyperlink."
                          set myHyperlink to make hyperlink with properties {source:myHyperlinkTextSource, destination:myHyperlinkPageDestination}
                          set myErrorString to "Cound not format hyperlink."
                          --Apply formatting to the hyperlink (could be done in the properties record, above).
                          set visible of myHyperlink to true
                          set border color of myHyperlink to blue
                          set border style of myHyperlink to solid
                          on error
                          display dialog myErrorString
                          end try
                          end if
                          end tell
                          end if
                          end if
                          end tell
                          Ole
