1 Reply Latest reply on Nov 15, 2010 9:39 AM by JohnDevlon
    [CS4][JS] How to detect the XMLelement type ?
      Can anyone please help me ?
      I've written a small loop that check's every XML element. I'm trying to find out if the XMLelement contains text so I can replace the text, or if the XMLelement is a image, so i can replace the image.
      Does anyone know how i can detect the XML element type?
        • 1. Re: [CS4][JS] How to detect the XMLelement type ?
          JohnDevlon Level 1
          Hi everybody,
          After some testing I found this solution :
          if(!( elm.xmlAttributes.item("href") == null)){
                   // if element contains href attribute, it must be a image tag
                  var myImageFullPatch = myImageFolder.fsName + "/" + myImageName;
                  var myRectangle = elm.xmlContent.parent;
          } else {
                 // Check if the element has text
                  if(!( elm.contents == null)){
                        // the element has text. Replace the text
                       elm.contents = myText;
          It works for me but is this the best solution ?
