3 Replies Latest reply: Nov 12, 2010 3:21 PM by chodorowicz_ RSS
    Adding JPEG 50kb - Output PNG 500kb
    green_mamut
      Hello,
      the following problem was already discussed in the following thread and we didn't find any solution.
      http://forums.adobe.com/message/3266129#3266129
      The problem is:
      I'm adding to my project JPEG image for example 600x400 50kb - after exporting it to SWF by using "export images as separate file" Rome converts this file to PNG and the file size is exploding to 500kb ...
      It's equal if I'm using layer stack, clipping frame or if I export all in one SWF file, the size is always the same.
      Please for solution!
      M.
        • 1. Re: Adding JPEG 50kb - Output PNG 500kb
          SarahEssary Community Member
          Hello,
          Our development team has provided me with the following answer: PNG is a lossless compression format whereas JPEG uses a lossy compression algorithm.
          Thanks again for your feedback,
          Sarah
          Sarah
          Forum Moderator
          • 2. Re: Adding JPEG 50kb - Output PNG 500kb
            green_mamut Community Member
            Hello,
            I know very well the Pro's and Contra's of  PNG and JPEG but if I already have an image that is compressed it's not normal that I get out something in the same quality, only the file size is 10x bigger... How is some on in this project imaging that users would like to add a gallery to their web sites with for example 15pix each of them 200kb - JPEG size... I will get and SWF file that nobody will be able to load because it's 30mb ... I'm sorry, but usually I can compress images very well in SWF file's ... example www.losynskiy.de - the whole site is 1,5mb with 33 Images ...
            So another solution and answer is needed ..
            Greetigns
            M.
            • 3. Re: Adding JPEG 50kb - Output PNG 500kb
              chodorowicz_
              Yeah, come on, it's evidently a bug! Nobody is gonna make slideshows with pictures without transparency in PNG format - this format was just not made for it. If I'm importing JPG then exporting it as PNG won't make the quality better.
              From what I've seen ROME already has possibility to export JPG images through Output->Output Channels->File Export->JPG (but only as seperate composition elements, not as a part of a whole project)
