1 Reply Latest reply on Nov 10, 2010 1:27 PM by Muppet Mark-QAl63s
    Activating More Than One InDesign Document
    jo2mendoza
      I need some assistance in AppleScript for InDesign CS2.
      I need to copy text from one InDesign CS2 document to another InDesign CS2 document. I already know the AppleScript commands to copy and paste the text.
      But what I am getting stuck is the command to activate the second document. After I copy the item from document 1, I need to paste it in document 2. But I don't know the command to activate the other document. I was hoping a simple command like:
      "activate lower document" or
      "activate other document" or
      "activate second document" or
      "activate document 'Untitled-2'...
      would work, but all of the above give me errors or do not work.
      Any suggestions will be appreciated.
        • 1. Re: Activating More Than One InDesign Document
          Muppet Mark-QAl63s Level 4
          You have a list of documents but there is only the one active document. So just loop thru the others setting them to the active one in turn…
          Something like:
          tell application "Adobe InDesign CS2"
          tell the active document
          -- do your copy stuff here…
          display dialog (name as text) giving up after 2
          end tell
          repeat with i from 2 to count of documents
          set the active document to document i
          --do your paste stuff here…
          end tell
          end repeat
          end tell
