4 Replies Latest reply on Nov 15, 2010 2:34 AM by daslicht
    'Animating' variables ? Crossfading Soundcontext
    daslicht Level 2
      Hello,
      I know hoa to use the Spark Animate, but to use it you need to specify a target object and a property.
      But how to I animate for example a Number or another variable e.g: a Integer?
      I like to crossfade the Volume of two Soundchannels.
        • 1. Re: 'Animating' variables ? Crossfading Soundcontext
          Shongrunden Adobe Employee
          I'm not sure I understand, I'm guessing you want to animate a property on your application?  If so here's an example:
                         xmlns:s="library://ns.adobe.com/flex/spark">
              <fx:Script>
                  <![CDATA[
                      [Bindable] public var myNumber:Number = 0;
              </fx:Script>
              <fx:Declarations>
                  <s:Animate id="myAnimate" target="{this}" duration="5000">
                      <s:motionPaths>
                          <s:SimpleMotionPath property="myNumber" valueBy="0.1" valueFrom="0" valueTo="100" />
                      </s:motionPaths>
                  </s:Animate>
              </fx:Declarations>
              <s:controlBarContent>
                  <s:Button label="animate number" click="myAnimate.play()"/>
              </s:controlBarContent>
              <s:Label text="{myNumber}" />
          </s:Application>
          Using valueBy works nicely for integers and numbers, but if you need more control over that you can look into creating a custom interpolator.  See this post for an example: http://forums.adobe.com/message/3140616#3140616
          • 2. Re: 'Animating' variables ? Crossfading Soundcontext
            daslicht Level 2
            Thank you very much!
            Do you know how I can call a function while the number is changing ?
            I try it with help of a Timer and post be results later.
            Thank you again for your time!
            Marc
            • 3. Re: 'Animating' variables ? Crossfading Soundcontext
              You could create getter/setter methods for the variable:
                  <fx:Script>
                      <![CDATA[
                          [Bindable] private var _myNumber:Number = 0;
                          [Bindable]
                          public function set myNumber(value:Number):void {
                              // set the number
                              _myNumber = value;
                              // call some function
                              myFunction();
                          public function get myNumber():Number {
                              return _myNumber;
                          private function myFunction():void {
                              trace("function called");
                  </fx:Script>
                  <fx:Declarations>
                          <s:motionPaths>
                          </s:motionPaths>
                      </s:Animate>
                  </fx:Declarations>
              </s:Application>
              • 4. Re: 'Animating' variables ? Crossfading Soundcontext
                daslicht Level 2
                Hello,
                I found the error why the property animation was not working.
                My variable to animate was set to private
                Thank you very much for taling time !
                Here is  y anti-leak test Flex shoutcast player :
                http://wensauer.info/flex/ShoutcastPlayer/ShoutcastPlayer.html
