4 Replies Latest reply on Nov 17, 2010 9:10 AM by chrisw1229
    Flash Builder + WTP = "Export Release Build" Broken
    chrisw1229
      If I create a combined Flex/Java project and then click the "Export Release Build..." menu, then nothing appears to happen. If I just create a plain Flex project, then it works just fine.
      I used the Eclipse Plug-in installer 4.0.1 (build 277662) for Windows XP SP3.
      I am running the bundled 3.4.2 version of Eclpse and installed Subclipse and the WTP plugin.
      I eventually looked through the Eclipse workspace log file and found the following stack trace. If anyone can offer me any suggestions on how to get this working I would appreciate it.
      !ENTRY org.eclipse.ui 4 0 2010-11-11 15:54:01.577
      !MESSAGE Unhandled event loop exception
      !STACK 0
      java.lang.NullPointerException
          at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.getDefaultOutputFolderPath(ExportReleaseVersionProjectAndLocationPage.java:485)
          at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.createLocationControls(ExportReleaseVersionProjectAndLocationPage.java:399)
          at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.createControl(ExportReleaseVersionProjectAndLocationPage.java:702)
          at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:170)
          at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.createPag eControls(ExportReleaseVersionWizard.java:471)
          at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:669)
          at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:543)
          at org.eclipse.jface.window.Window.create(Window.java:431)
          at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
          at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction$1.run(Export ReleaseVersionAction.java:93)
          at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction.run(ExportRe leaseVersionAction.java:103)
          at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
          at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
          at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:583)
          at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:500)
          at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java :452)
          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
          at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2384)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2200)
          at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:490)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
      Chris Ward
        • 1. Re: Flash Builder + WTP = "Export Release Build" Broken
          Sedat Akkus Adobe Employee
          Hi Chris,
          Are you using Flash Builder "Burrito"? The stack trace seems outdated to me.
          -Sedat
          • 2. Re: Flash Builder + WTP = "Export Release Build" Broken
            chrisw1229 Level 1
            I don't believe I'm using the Burrito build, as I thought that was still considered experimental. I downloaded the installer from here:
            http://www.adobe.com/cfusion/tdrc/index.cfm?product=flash_builder
            It looks like I downloaded the installer on October 8th, and as I said in the original post the version listed in Help -> About is: 4.0.1 (build 277662)
            If you need me to check anything else, just let me know. In order to work around the problem for the moment, I made an Ant build file to export releases, which I would have probably wanted to do anyway. Still, it would be good to figure out what is causing the problem.
            Chris Ward
            • 3. Re: Flash Builder + WTP = "Export Release Build" Broken
              SwathiRR
              Hi
              I was able to reproduce this issue with  Eclipse 3.6 and burrito build.
              When I create a flex/java project I am not able to export the release build and the null pointer exception occurs.
              But when I create the flex/java project with remote object service as LCDS export worked fine.
              Also export of normal project is worked fine. I  raised a bug http://bugs.adobe.com/jira/browse/FB-29046 for the same
              I am  attaching the logs here
              ENTRY org.eclipse.ui 4 0 2010-11-17 10:52:09.360
              !STACK 0
              at  com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionMainPageContent. getDefaultOutputFolderPath(ExportReleaseVersionMainPageContent.java:581)
              at  com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionMainPageContent. createLocationControls(ExportReleaseVersionMainPageContent.java:282)
              at  com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionMainPageContent. createControls(ExportReleaseVersionMainPageContent.java:193)
              at  com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.createControl(ExportReleaseVersionProjectAndLocationPage.java:188)
              at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1226)
              at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1218)
              at org.eclipse.jface.wizard.WizardDialog$6.run(WizardDialog.java:1207)
              at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
              at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1205)
              at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:894)
              at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:426)
              at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
              at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
              at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
              at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
              at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
              at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
              at org.eclipse.jface.window.Window.open(Window.java:801)
              at org.eclipse.ui.internal.handlers.WizardHandler$Export.executeHandler(WizardHandler.java:9 8)
              at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:274)
              at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
              at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
              at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.jav a:508)
              at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
              at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.j ava:241)
              at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
              at org.eclipse.ui.internal.actions.CommandAction.run(CommandAction.java:171)
              at org.eclipse.ui.actions.ExportResourcesAction.run(ExportResourcesAction.java:116)
              at org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEvent(BaseSelectionListenerActi on.java:168)
              at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
              at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
              at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
              at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
              at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
              at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
              at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
              at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
              Thanks and Regards
              Swathi
              • 4. Re: Flash Builder + WTP = "Export Release Build" Broken
                chrisw1229 Level 1
                Yes, I selected Java/EE for the application server type and unchecked the box for "Use remote object access service" because I'm not using any of those technologies. So based on what you said, the problem seems to be related to that choice.
                Chris Ward
