5 Replies Latest reply: Aug 9, 2011 2:22 PM by cromaline RSS
    Changing icon ?
    themandarin1 Community Member
        I have created my panels and all is working well. However, i would to change the icon when the panels are minimized as if you have say 2-4 panels the icons are the same hence impossible to distinguish.
      Can that be done ?
      Cheers
        • 1. Re: Changing icon ?
          cromaline Community Member
          1)Create two png files ( 23px x 23 px or 25x25 ) and name them respectively with the name of the panel you created  :
          Substitute panel name ( in my example) with your own panel's name and be sure to add Normal and Rollover  with no space between them and the end of our panel's name
          Rollover is the icon state when your mouse is over it
          2) Once your panel is exported put the  two .png files inside his "content" folder as in the image below
          3)Restart Photoshop
          • 2. Re: Changing icon ?
            7 GRAD PLUS Community Member
            This doesn't seem to work anymore
            I did as told, but the Panel still has the "standard" icon.
            Any ideas?
            Thx in advance!
            • 3. Re: Changing icon ?
              It should
              That is the right way,all is ok with me,  may be there is something not  written in the right way
              does a check for the correct panel name ( mantain the same space it has)  and  checks also that "Normal" and "Rollover" are placed attached to the panel name
              Check also  if in the exported panel ( in Photoshop) are the two icons
              • 4. Re: Changing icon ?
                thx for your response!
                didn't try in photoshop. i build a indesign-panel.
                but i try quick with a PS panel and the two files. maybe it's not supported for indesign-panels.
                • 5. Re: Changing icon ?
                  as soon as I find time I will do a test with indesign
