1 Reply Latest reply on Nov 15, 2010 11:28 AM by Mayank (Adobe)
    Problem running Burrito sample data connection app
    Amit_Mathur
      Hi, I have started the tutorial for Flash Builder Burito ( for Anfroid) given at link
      http://www.adobe.com/devnet/flex/testdrivemobile/articles/mtd_1_2.html
      1. I m facing problem while creating data connection (java clases) ----  step named "Create a Flex data service" in tutorial.
      2 I have installed apache and deployed testdrive war and I can see the employee data through the browser.
      3  When i try to create data service as mentioned below .......
      Step 1: Create a Flex data service.
      Use the Data menu and the Service Wizard to create a service for your application server. For ColdFusion and PHP, specify the service file you put on your application server earlier (see Figure 1 for a PHP example). For Java, select the No password required check box, select the employeeService destination, and change the service package to services.employeeservice.
      ........ I get the following error on clicking Data(menu) ---> Connect to data/service
      Why  is this RDS problem ? Am I missing something ... Please suggest.
      Regards
      Amit
