4 Replies Latest reply on Nov 15, 2010 3:47 AM by Cookie4ddict
    Problem with checking file existence by using app.openDoc
    Cookie4ddict
      Hi Folks,
      I have to create a script for a big project with many PDF's. (Just like Ingrimm - it's the same company http://forums.adobe.com/thread/747022?tstart=0) This PDF's are made of scanned images. I need to rename the files to names that are extracted from within the file. This is working without problems.
      Now there could be the case, that a filename exists already. I don't want the files to be overwritten, so the idea is, that already existing filenames are saved as filename_1, filename_2, etc... (Before I merged them, but this isn't what is wanted.)
      For this reason I need to use app.openDoc to check, if a file exists. Yesterday my script worked fine, but after starting it today, I discovered that it started again to overwrite files which are already existing.
      I added an app.alert to my catch method to see what error is thrown. The message is: 'NotAllowedError: Security settings prevent access to this property or method.'.
      After using google, I found out, that Acrobat is not finding any files. But I checked and there are files which should be doubled.
      I have no idea how to fix that problem. Anybody here who can help me?
      Regards,
      Steffi
      * regular expression for search
      var idNumber = /08\d\d\d\d\-\d\d\d\-\d\d\d\d\d-\d\d\d/g;
      * if possible this function extracts the searched number as string
      * @param rematch string which should be searched in document
      * @return null if rematch is not found or string if rematch is found
      function ExtractFromDocument(reMatch) {
        try {
               var Out = new Object();
               for (var i = 0; i < 1; i++)
                numWords = this.getPageNumWords(i);
                var PageText = "";
                for (var j = 0; j < 30;j++) {
                    var word = this.getPageNthWord(i,j,false);
                    PageText += word;
                var strMatches = PageText.match(reMatch);
                if (strMatches == null) continue;
            return strMatches;
        } catch(e)
            app.alert("Processing error: "+e)
      * tries to load given filename (extracted number)
      * @param filename string of file which should be checked
      * @param n number to iterate while checking for files
      * @return true if file exists or false if not
      function checkIfFileExists(filename, n) {
          var existingDoc = false;
          try {
              if( n == 0) {
                  var checkDoc = app.openDoc({cPath : "../GAG-out/"+filename+"-001.pdf"});
              } else {
                  var checkDoc = app.openDoc({cPath : "../GAG-out/"+filename+"-001_"+n+".pdf"});
              checkDoc.closeDoc();
              existingDoc = true;
          } catch (e) {
          if( existingDoc == true ) {
              n = n+1;
              n = checkIfFileExists(filename, n);
          return n;
      var filename = ExtractFromDocument(idNumber);
      if(filename == null || filename == undefined) {
        filename = Math.round(Math.random()*999999999999);
        this.extractPages({nEnd:(this.numPages-1), cPath : "../GAG-out/n_"+filename+".pdf"});
      } else {
          fileExistence = checkIfFileExists(filename, 0);
          if(fileExistence != 0) {
              this.extractPages({nEnd:(this.numPages-1), cPath : "../GAG-out/"+filename+"-001_"+fileExistence+".pdf"});
          } else {
              this.extractPages({nEnd:(this.numPages-1), cPath : "../GAG-out/"+filename+"-001.pdf"});
