2 Replies Latest reply on Nov 29, 2010 4:41 AM by Tiki Howpu
    SQLStatement IN operator : Data type mismatch
    Tiki Howpu
      I have this in my AIR application:
      var relatedQuery:SQLStatement = new SQLStatement();
      relatedQuery.sqlConnection = myConnection;
      relatedQuery.addEventListener( SQLEvent.RESULT, queryResult );
      relatedQuery.addEventListener( SQLErrorEvent.ERROR, onError );
      queryString:String = "SELECT * FROM tbl_sheet WHERE  tbl_sheet.sheet_nID IN ( :pSheetIDList ) ";
      relatedQuery.parameters[":pSheetIDList"] = nSheetIDList;
      relatedQuery.text = queryString;
      relatedQuery.execute();
      The nSheetIDList is an Array like this :  14563,14549,14556,14557
      And the database column sheet_nID is an INTEGER type.
      When running debug-mode it gives an error:
      Error #3132: Data type mismatch.', details:'could not convert text value to numeric value'.
      Any ideas what's wrong with the above?
        • 1. Re: SQLStatement IN operator : Data type mismatch
          Alexandru Nicau
          You're trying to pass an Array as query parameter and that's not supported. Here is the list of allowed datatypes: TEXT (or String), NUMERIC, INTEGER (or int), REAL (or Number), Boolean, Date, XML, XMLLIST, Object and NONE. Object cannot be used for that purpose, is useful when you serialize/store/deserialize entire AS objects.
          For further reading - scroll down to SQL support in local databases, Column affinity
          http://help.adobe.com/en_US/as3/dev/WSd47bd22bdd97276f2aceae3b1262b7f2d43-8000.html
          I would suggest as fast workaround using a set of unnamed parameters
          http://livedocs.adobe.com/flex/3/html/help.html?content=SQL_06.html
          relatedQuery = new SQLStatement();
          //example array to be replaced with nSheetIDList
          var oneArray:Array = new Array("1", "2");
          var i: uint;
          var paramString : String = "";
          //build a short string with question marks
          for (i = 0; i < oneArray.length; ++i)
              paramString += '? ,';
          //remove the last ',' because nothing follows
          paramString = paramString.substring(0, paramString.length - 1);
          var queryString:String = "SELECT * FROM tbl_sheet WHERE sheet_nID IN (" + paramString + ")";
              relatedQuery.parameters[i] = oneArray[i];    //zero based index, link each unnamed parameter with the corresponding array value
          have fun,
          Alex.
          • 2. Re: SQLStatement IN operator : Data type mismatch
            Tiki Howpu Level 1
            Thank you, it works now
