3 Replies Latest reply on Nov 15, 2010 1:16 AM by TimEm
    Links to Design-Time controls not working
    TimEm
      Hi
      This is a bit historic but years ago when using robohelp to generate hlp files I used to create links from piece of text to to a see also control that was hidden thus enabling see also links from the text.
      When I upgraded to generate HTML help (chm files) this still worked even though I could not work out how to recrete it uisng the UI of Robohelp. I was able to copy and paste stuff and modify the HTML so that I could create similar links.
      I have just upgraded to Robohelp 8 and these links no longer work. I get the following error:
      `An error has occured in the script on this page`
      The links work when compiled in version 7
      Below is a sample of the code for the link
      Robohelp 8
      <a href="javascript:RelatedTopic1.Click()" class="popuplk">Set up I/O modules</a>
      Robohelp 7 (works)
      Code looks the same.
      Would be grateful for any help on how to fix this, or an alternative method.
      Tim
