3 Replies Latest reply on Nov 12, 2010 11:37 AM by Shongrunden
    Hero MobileIconItemRenderer label and message functions
    dsmith@genitron
      While I have done a lot of Flash animations, I am relatively new to ActionScript, and Burrito is my very first experience with Flash Builder.
      I've gone through the available tutorials using this component, and have even built my own http/JSON data driven app. Now i'm experimenting a little with list formatting.
      I'm trying to use various components' function calls to format my list item outputs. For instance, I was able to create and use the "LabelFunction" in the <s:List> component to do some simple modifying of the list label field from there.
      There are similar functions in the MobileIconItemRenderer component called "labelFunction" and "messageFunction", but I have not been able to access any functions I create for them. Actually, I m not sure where to put them. They are not seen if I put them in the main <fx:script> section of the view, like i did with the <s:list> component.
      1120: Access of undefined property my_Function. view3.mxml /Test/src/views line 111 Flex Problem
      Has anyone used these function calls in MobileIconItem Renderer?
      Where do i put those functions?
        • 1. Re: Hero MobileIconItemRenderer label and message functions
          Jason San Jose Adobe Employee
          Move to Flex forum. Renamed to Hero (SDK) from Burrito (FB).
          • 2. Re: Hero MobileIconItemRenderer label and message functions
            SashaKeith Adobe Employee
            Here's a sample on how to do this:
                <s:List dataProvider="{items}" left="0" right="0" top="0" bottom="0">
                    <s:itemRenderer>
                        <fx:Component>
                            <s:MobileIconItemRenderer labelFunction="lblFunction" messageField="message">
                                <fx:Script>
                                    <![CDATA[
                                        private function lblFunction(item:Object):String
                                            return item.label + "_2010";
                                </fx:Script>
                            </s:MobileIconItemRenderer>
                        </fx:Component>
                    </s:itemRenderer>
                </s:List>
            • 3. Re: Hero MobileIconItemRenderer label and message functions
              Shongrunden Adobe Employee
              Good question, this can be a little tricky if you are new to MXML.  The fx:Component construct defines a new document scope so you could put another script tag in there or refer to methods in the main document via the outerDocument keyword:
              Here's an example:
              <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:s="library://ns.adobe.com/flex/spark" title="Home">
                  <fx:Script>
                      <![CDATA[
                          public function messageFunction(item:Object):String {
                              return "outer message function";
                  </fx:Script>
                  <s:HGroup>
                      <s:List>
                          <s:itemRenderer>
                              <fx:Component>
                                  <s:MobileIconItemRenderer messageFunction="innerMessageFunction">
                                      <fx:Script>
                                          <![CDATA[
                                              public function innerMessageFunction(item:Object):String {
                                                  return "inner message function"
                                      </fx:Script>
                              </fx:Component>
                          </s:itemRenderer>
                          <s:dataProvider>
                              <s:ArrayList>
                                  <s:source>
                                      [1,2,3,4]
                                  </s:source>
                              </s:ArrayList>
                          </s:dataProvider>
                      </s:List>
                      <s:List>
                          <s:itemRenderer>
                              <fx:Component>
                                  <s:MobileIconItemRenderer messageFunction="{outerDocument.messageFunction}" />
                              </fx:Component>
                          </s:itemRenderer>
                          <s:dataProvider>
                              <s:ArrayList>
                                  <s:source>
                                      [1,2,3,4]
                                  </s:source>
                              </s:ArrayList>
                          </s:dataProvider>
                      </s:List>
                  </s:HGroup>
              </s:View>
