1. Re: Can't set width of submenu properly
Ben Pleysier Nov 13, 2010 3:53 PM (in response to thersher)There are 4 places where the width can be stipulated
ul.MenuBarHorizontal {
width: auto;
}This gives a width to the total SpryMenuBar
ul.MenuBarHorizontal li {
width: 8.2em;
}This is the width for all menu items (both main menu and submenus)
ul.MenuBarHorizontal ul {
width: 8.2em;
}This is the width of the container for the submenus. This is usefull if you wish to have multiple rows within the submenu drop-down.
ul.MenuBarHorizontal ul li {
width: 8.2em;
}This overrides the menu item width set above and applies only to submenus
If you want to set unique menu item widths, this can be achieve using an inline style rule as per following
<li style="width: 3em;><a href="#">Item 1</a></li>
<li><a href="#">Item 2</a></li>
<li style="width: 17em;><a href="#">Item 3</a></li>
<li><a href="#">Item 4</a></li>Items 2 and 4 will use the width as stipulated in the style sheet, the widths for items 1 and 3 have been overridden by the inline style rules.
I hop the above will allow you to do what you want.
Gramps
2. Re: Can't set width of submenu properly
thersher Nov 15, 2010 6:52 PM (in response to Ben Pleysier)I'm still doing something wrong. Now I have the same problem on another site as well (the first site I have done a temporary work around). The
site is http://www.bandhropehalters.com > Shop Online menu item. I have set the ul.MenuBarHorizontal ul li line to 17 em, which is way wider than necessary, but it still only shows up a certain width. When I make the change in DW, it displays properly for me, but then when I preview or upload the changes, it's not working properly.
What am I missing here?
3. Re: Can't set width of submenu properly
Ben Pleysier Nov 15, 2010 10:13 PM (in response to thersher)I guess I have to repeat what I have said before
width: 8.2em;
Try changing the above value form 8.2 to 16em
Cheers,
Gramps
4. Re: Can't set width of submenu properly
thersher Nov 16, 2010 5:32 AM (in response to Ben Pleysier)Thank you, sorry about that, I misread it, thinking that would widen the main containers as well. That worked great, I appreciate the help!
