3 Replies Latest reply on Nov 13, 2010 12:35 PM by Mirada2000
    PRE9 error install
    Mirada2000
      Premiere Elements 9 fails during installation, it tells me that it was because of shared technology.
      I tried as mentioned in another topic of disabled all adobe products under msconfig but nothing has changed, log attached.
      Thank You
      Visit http://www.adobe.com/go/loganalyzer/ for more information
      START - Installer Session
      RIBS version: 3.5.8.0
      Win OS version: 6.0.2.0  Type: 1
      ::START TIMER:: [Total Timer]
      CHECK: Single instance running
      CHECK : Credentials
      Load Deployment File
      Create Required Folders
      Assuming install mode
      Looking up install source path
      Sync Media DB ...
      ::START TIMER:: [Sync Media DB]
      Pre check media db sync
      End of Pre check media db sync. Exit code: 0
      :: END TIMER :: [Sync Media DB] took 1103.76 miliseconds (1.10376 seconds)
      Ready to initialize session to start with ...
      ::START TIMER:: [CreatePayloadSession]
      -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
      Updated source path: E:\PRE 9\ElementsSTIInstaller
      Updating media info for: {1A7439BF-B037-4580-9F31-618CCACCC482}
        Type: 1, Volume Order: 1, Media Name: PRE 9
        Path: E:\ElementsSTIInstaller\payloads\ElementsCameraRaw6.1All\Install.db
      Updating media info for: {25175695-4B20-4298-9F34-C2C57CD277B3}
        Path: E:\ElementsSTIInstaller\payloads\ElementsSTIInstaller\Install.db
      Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
        Path: E:\ElementsSTIInstaller\payloads\AdobeAPE3-mul\Install.db
      Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
        Path: E:\ElementsSTIInstaller\payloads\AdobeCameraRawProfile6.0All\Install.db
      Updating media info for: {93EE4FE8-6892-11DF-9F6A-6A14DFD72085}
        Path: E:\ElementsSTIInstaller\payloads\AdobeHelp\AIRInstallerRunner.exe
      --------------------  END  - Updating Media Sources -  END  --------------------
      Supported RIBS version range: [0.0.66.0,3.5.8.0]
      ----------------- CreatePayloadSession: machine is x86 ---------------
      [    3108] Sat Nov 13 12:48:07 2010  INFO
      ______ Verify Dependency Subscribers ______
      [    3108] Sat Nov 13 12:48:07 2010  WARN
      Payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is already installed and the session payload {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} AdobeHelp has no upgrage/conflict relationship with it.
      [    3108] Sat Nov 13 12:48:07 2010 ERROR
      Verifying payload integerity : Failed with code 1
      Ignoring deployment input for the INSTALLDIR: marked as fixed
      Found payload actions:
      Deciding what installer mode to use...
      BEGIN Setting requested payload actions
      Value returned on lookup of payload: {FB964403-C72E-4D32-A690-5398B05447EE} Camera Profiles Installer_6.2_AdobeCameraRawProfile6.0All is: true
      Action string for  {FB964403-C72E-4D32-A690-5398B05447EE} Camera Profiles Installer_6.2_AdobeCameraRawProfile6.0All  is none
      Payload {FB964403-C72E-4D32-A690-5398B05447EE} Camera Profiles Installer_6.2_AdobeCameraRawProfile6.0All is extension payload. Aligning its action according to parent.
      Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: true
      Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none
      Value returned on lookup of payload: {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is: true
      Action string for  {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul  is none
      Payload {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is extension payload. Aligning its action according to parent.
      Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: true
      Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none
      Value returned on lookup of payload: {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} AdobeHelp is: true
      Action string for  {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} AdobeHelp  is none
      Value returned on lookup of payload: {AFA9202E-59F6-4410-A2DF-5FCD43C1CAC4} Elements Camera Raw_6.2_ElementsCameraRaw6.1All is: true
      Action string for  {AFA9202E-59F6-4410-A2DF-5FCD43C1CAC4} Elements Camera Raw_6.2_ElementsCameraRaw6.1All  is none
      Payload {AFA9202E-59F6-4410-A2DF-5FCD43C1CAC4} Elements Camera Raw_6.2_ElementsCameraRaw6.1All is extension payload. Aligning its action according to parent.
      Value returned on lookup of payload: {1A7439BF-B037-4580-9F31-618CCACCC482} Elements Camera Raw is: true
      Action string for  {1A7439BF-B037-4580-9F31-618CCACCC482} Elements Camera Raw  is none
      Value returned on lookup of payload: {25175695-4B20-4298-9F34-C2C57CD277B3} ElementsSTIInstallerPRE is: false
      Action string for  {25175695-4B20-4298-9F34-C2C57CD277B3} ElementsSTIInstallerPRE  is install
      END Setting requested payload actions
      {1A7439BF-B037-4580-9F31-618CCACCC482} Elements Camera Raw: payload not found in the local payloads folder
      {25175695-4B20-4298-9F34-C2C57CD277B3} ElementsSTIInstallerPRE: payload not found in the local payloads folder
      {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding: payload not found in the local payloads folder
      {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer: payload not found in the local payloads folder
      {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} AdobeHelp: payload not found in the local payloads folder
      Removable media cannot be used for silent installation; please copy payloads to the local "payloads" folder to proceed
      :: END TIMER :: [Total Timer] took 2339.82 miliseconds (2.33982 seconds) DTR = 5.1286 KBPS (0.0050084 MBPS)
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 7 error(s), 1 warning(s)
      WARNING: Payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is already installed and the session payload {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} AdobeHelp has no upgrage/conflict relationship with it.
      ERROR: Verifying payload integerity : Failed with code 1
      ERROR: {1A7439BF-B037-4580-9F31-618CCACCC482} Elements Camera Raw: payload not found in the local payloads folder
      ERROR: {25175695-4B20-4298-9F34-C2C57CD277B3} ElementsSTIInstallerPRE: payload not found in the local payloads folder
      ERROR: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding: payload not found in the local payloads folder
      ERROR: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer: payload not found in the local payloads folder
      ERROR: {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} AdobeHelp: payload not found in the local payloads folder
      ERROR: Removable media cannot be used for silent installation; please copy payloads to the local "payloads" folder to proceed
      Search the same string above to find when the error occured.
      Exit Code: 26 - Media swap required to continue installation, cannot proceed
      END - Installer Session
      CHECK : Credentials
      Sync Media DB ...
      :: END TIMER :: [Sync Media DB] took 1018.09 miliseconds (1.01809 seconds)
      [     244] Sat Nov 13 13:02:30 2010  WARN
      [     244] Sat Nov 13 13:02:30 2010 ERROR
      [     244] Sat Nov 13 13:02:30 2010  INFO
      :: END TIMER :: [Total Timer] took 1941.87 miliseconds (1.94187 seconds) DTR = 4.11973 KBPS (0.00402318 MBPS)
      CHECK : Credentials
      ::START TIMER:: [Bootstrap]
      Perform Bootstrapping ...
      :: END TIMER :: [Bootstrap] took 11104.9 miliseconds (11.1049 seconds) DTR = 34.219 KBPS (0.033417 MBPS)
      Sync Media DB ...
      :: END TIMER :: [Sync Media DB] took 585.041 miliseconds (0.585041 seconds)
      [    2712] Sat Nov 13 13:06:33 2010  INFO
      [    2712] Sat Nov 13 13:06:33 2010  WARN
      [    2712] Sat Nov 13 13:06:33 2010 ERROR
      Setting property "installLanguage" to: fr_CA
      Attempting to find the selected language in the set of available payload languages
      Setting property "installSourcePath" to: E:\PRE 9\ElementsSTIInstaller
      Overwrite property "userASUPath" to: C:\Users\Bruno\AppData\Local\Adobe\OOBE\PDApp
      Collected advanced path check information for INSTALLDIR
      INSTALLDIR is a well-formed path
      INSTALLDIR is not the root path
      INSTALLDIR is on a local volume
      INSTALLDIR is on a writable volume
      INSTALLDIR is not on a case sensitive volume
      INSTALLDIR passed path basic path validation: C:\Program Files\Common Files\Adobe\Elements STI Installer
      [    2712] Sat Nov 13 13:06:34 2010  WARN
      Warning: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
      Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
      Warning: {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} AdobeHelp will not be repaired. Only language packs will be installed for it.
      Warning: {1A7439BF-B037-4580-9F31-618CCACCC482} Elements Camera Raw will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
      [    2712] Sat Nov 13 13:06:34 2010  INFO
      Payloads passed preflight validation.
      Call PreSession Custom Hook
      Disk Swap Needed, Prompting user to swap disk PRE 9 E:\
      [    2712] Sat Nov 13 13:06:39 2010  INFO
      [    2712] Sat Nov 13 13:06:43 2010 ERROR
      Set payload canceled status
      [    2712] Sat Nov 13 13:06:43 2010  INFO
      No operation.  We're done:
      Updating driver data - Action: Remove driver entry
      Updating driver data successful. Driver entry was added. ARP estimated size 603681KB
      [    2712] Sat Nov 13 13:06:44 2010 ERROR
      Payload {1A7439BF-B037-4580-9F31-618CCACCC482} has an action "repair" but no resultState
      Payload {25175695-4B20-4298-9F34-C2C57CD277B3} has an action "install" but no resultState
      Payload {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} has an action "repair" but no resultState
      Payload {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} has an action "repair" but no resultState
      [    2712] Sat Nov 13 13:06:46 2010  INFO
      Total components installed: 0
      Total components repaired: 0
      Total components removed: 0
      [    2712] Sat Nov 13 13:06:46 2010 ERROR
      The following payload errors were found during install:
      - Camera Profiles Installer: User canceled installation
      User cancelled the operation
      Restarting your computer is recommended:
      In order to complete the installation, please restart the computer
      Call PostSession Custom Hook
      :: END TIMER :: [Total Timer] took 24978.5 miliseconds (24.9785 seconds) DTR = 32.6681 KBPS (0.0319025 MBPS)
      - 0 fatal error(s), 9 error(s), 5 warning(s)
      WARNING: Warning: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
      WARNING: Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
      WARNING: Warning: {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} AdobeHelp will not be repaired. Only language packs will be installed for it.
      WARNING: Warning: {1A7439BF-B037-4580-9F31-618CCACCC482} Elements Camera Raw will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
      ERROR: Set payload canceled status
      ERROR: Payload {1A7439BF-B037-4580-9F31-618CCACCC482} has an action "repair" but no resultState
      ERROR: Payload {25175695-4B20-4298-9F34-C2C57CD277B3} has an action "install" but no resultState
      ERROR: Payload {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} has an action "repair" but no resultState
      ERROR: Payload {93EE4FE8-6892-11DF-9F6A-6A14DFD72085} has an action "repair" but no resultState
      ERROR: The following payload errors were found during install:
      ERROR:  - Camera Profiles Installer: User canceled installation
      ERROR: User cancelled the operation
      Exit Code: 24 - User cancelled out of install/uninstall/reinstall
      [    3692] Sat Nov 13 13:31:29 2010  INFO
      CHECK : Credentials
      Sync Media DB ...
      End of Pre check media db sync. Exit code: 1
      Media db sync skipped as session is already installed
      :: END TIMER :: [Sync Media DB] took 83.6772 miliseconds (0.0836772 seconds)
      [    3692] Sat Nov 13 13:31:29 2010  WARN
      [    3692] Sat Nov 13 13:31:29 2010 ERROR
      :: END TIMER :: [Total Timer] took 909.072 miliseconds (0.909072 seconds) DTR = 8.80019 KBPS (0.00859393 MBPS)
      CHECK : Credentials
      Sync Media DB ...
      :: END TIMER :: [Sync Media DB] took 54.9162 miliseconds (0.0549162 seconds)
      [    1936] Sat Nov 13 13:53:27 2010  INFO
      [    1936] Sat Nov 13 13:53:27 2010  WARN
      [    1936] Sat Nov 13 13:53:27 2010 ERROR
      :: END TIMER :: [Total Timer] took 987.368 miliseconds (0.987368 seconds) DTR = 526.653 KBPS (0.514309 MBPS)
      CHECK : Credentials
      Sync Media DB ...
      :: END TIMER :: [Sync Media DB] took 38.9662 miliseconds (0.0389662 seconds)
      [    2556] Sat Nov 13 14:04:30 2010  INFO
      [    2556] Sat Nov 13 14:04:30 2010  WARN
      [    2556] Sat Nov 13 14:04:30 2010 ERROR
      :: END TIMER :: [Total Timer] took 587.627 miliseconds (0.587627 seconds) DTR = 13.6141 KBPS (0.013295 MBPS)
