5 Replies Latest reply on Nov 17, 2010 6:26 PM by ChrisReed
    Crashing with USB input device
    ChrisReed
      I'm experiencing a crash when I attempt to record from a USB input device.  Also crashes when I attempt to make changes to the audio hardware settings (Audition > Preferences > Audio Hardware).  Playback works fine.
      The frustrating part is that it worked fine yesterday and I am not aware of any system changes that may have prompted the issue.  Tried reboot as well as a re-install of Audition, neither worked.  Running an iMac (2.5 GHz Core 2) and 10.5.8.
      Any thoughts would be much appreciated.
        • 1. Re: Crashing with USB input device
          _durin_ Adobe Employee
          Hi Chris,
          What USB Input device is this?  You might want to try overriding the preferences/settings and try selecting the device again and see if that clears this issue up.  To do so, launch Audition but hold down the SHIFT key while it starts up.  Then, enter the Audio Hardware preferences and select your input device again, then try recording once more.
          If it continues to crash, please be sure to submit the Adobe Crash Reporter if it pops up.  There will be a button at the bottom of that dialog that will let you view the Crash Log in your text editor.  If you wouldn't mind copying and pasting that into a reply, it might help us determine what's happening as well.
          • 2. Re: Crashing with USB input device
            ChrisReed Level 1
            Thanks for the suggestion.  Unfortunately, it didn't work.  I'm using an Alesis TapeLink USB deck which was working fine the first time I used the beta, and works fine with other audio software as well.  Interestingly, I also noticed that Audition "crashes" when I exit the program normally (e.g., if I launch Audition, do something other than try to record, then close it properly); it triggers the OS crash reporter, but not the Adobe crash reporter.
            As requested, here is a cut+paste of an Adobe crash report that occurred as a result of a recording attempt.  Sorry for the length -- I'm relatively savvy, but not sufficiently savvy to figure out which parts of the following are important.
            Thanks for your continued help.
            Process:         Adobe Audition [2464]
            Path:            /Users/chrisreed/Desktop/Adobe Audition.app/Contents/MacOS/Adobe Audition
            Identifier:      com.adobe.Audition.4.0
            Version:         4.0x10 (4.0)
            Code Type:       X86 (Native)
            Parent Process:  launchd [1485]
            Date/Time:       2010-11-15 20:24:00.540 -0500
            OS Version:      Mac OS X 10.5.8 (9L31a)
            Report Version:  6
            Anonymous UUID:  11B2D2D1-C5A4-4141-8C28-ADBEC38FF290
            Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
            Exception Codes: KERN_INVALID_ADDRESS at 0x00000000c0000003
            Crashed Thread:  17
            Thread 0:
            0   libSystem.B.dylib             0x9500c44e __semwait_signal + 10
            1   libSystem.B.dylib             0x9505c9f8 pthread_cond_timedwait$UNIX2003 + 72
            2   ...obe.boost_threads.framework 0x0006a2ae boost::this_thread::sleep(boost::posix_time::ptime const&) + 318
            3   com.adobe.aubackend.framework 0x0238d892 (anonymous namespace)::Sleep(unsigned int) + 146
            4   com.adobe.aubackend.framework 0x0238f66c CoreAudio::Device::StopDevice(unsigned long, long (*)(unsigned long, AudioTimeStamp const*, AudioBufferList const*, AudioTimeStamp const*, AudioBufferList*, AudioTimeStamp const*, void*), bool, bool, unsigned long) + 156
            5   com.adobe.aubackend.framework 0x0237b47e abe::IO::Audio::CoreAudioDevice::~CoreAudioDevice() + 206
            6   com.adobe.aubackend.framework 0x023677c3 abe::IO::Audio::MultiAudioDevice::~MultiAudioDevice() + 1075
            7   com.adobe.aubackend.framework 0x0235809e abe::IO::Audio::AudioDeviceMgrImpl::MakeCurrentDevice(boost::intrusive_ptr<abe::IO::Audio ::AudioDevice>) + 878
            8   com.adobe.aubackend.framework 0x02356d31 abe::IO::Audio::AudioDeviceMgrImpl::Notify(abe::IO::Audio::MessageWhat, abe::IO::Audio::MessageType, int, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >) + 369
            9   com.adobe.aubackend.framework 0x0234d06b abe::IO::Audio::NotifyAudioDeviceMgr(abe::IO::Audio::MessageWhat, abe::IO::Audio::MessageType, int, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >) + 91
            10  com.adobe.aubackend.framework 0x0234b9ca abe::IO::Audio::ScSignalBeginEnd::ScSignalBeginEnd(abe::IO::Audio::MessageType) + 106
            11  AuUI                          0x03d5986d aui::CoreAudioClassDriverPrefsPageController::ApplySettings(aui::HardwareClassDriverPrefs PageController::ApplySettingsType) + 93
            12  AuUI                          0x03d3b0c8 aui::HardwareClassDriverPrefsPage::CommitProps() + 136
            13  AuUI                          0x03d529a5 aui::HardwarePrefsPage::CommitProps() + 37
            14  com.adobe.dvaui.framework     0x007c374b dvaui::dialogs::UI_PagedDialog::RunModalAndProcessResponse(bool) + 219
            15  AuUI                          0x03d1def3 aui::preferences::PreferenceCommandHandler::OpenPrefsDialog(int, std::basic_string<char, std::char_traits<char>, std::allocator<char> >) + 2803
            16  AuUI                          0x03d2273a aui::preferences::PreferenceCommandHandler::OnOpenPrefsDialog(int) + 58
            17  AuUI                          0x03d228f2 boost::detail::function::function_obj_invoker1<boost::_bi::bind_t<bool, boost::_mfi::mf1<bool, aui::preferences::PreferenceCommandHandler, int>, boost::_bi::list2<boost::_bi::value<aui::preferences::PreferenceCommandHandler*>, boost::arg<1> (*)()> >, bool, int>::invoke(boost::detail::function::function_buffer&, int) + 82
            18  AuUI                          0x036585a6 exo::uisupport::CommandDispatcher<exo::uisupport::CommandAttachment>::DoHandleCommand(int ) + 86
            19  AuUI                          0x036586e7 aui::utility::CommandDispatcher<exo::uisupport::CommandAttachment>::DoHandleCommand(int) + 39
            20  com.adobe.exo.framework       0x01bfa003 exo::uisupport::CommandHandler::HandleCommand(int) + 195
            21  com.adobe.exo.framework       0x01bfa08c exo::uisupport::CommandHandler::DoCallMyCommandChain(int) + 28
            22  com.adobe.exo.framework       0x01bf80c5 exo::uisupport::CommandHandlerBase::CallCommandChain(int) + 69
            23  com.adobe.exo.framework       0x01b9773c exo::app::OS_AppBase::DispatchMenuCommand(int) + 108
            24  com.adobe.exo.framework       0x01b9b047 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, exo::app::OS_AppBase, int>, boost::_bi::list2<boost::_bi::value<exo::app::OS_AppBase*>, boost::_bi::value<int> > >, void>::invoke(boost::detail::function::function_buffer&) + 55
            25  com.adobe.dvacore.framework   0x0033f519 boost::function0<void>::operator()() const + 41
            26  com.adobe.dvacore.framework   0x0033e0a1 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 17
            27  com.adobe.dvacore.framework   0x0033e1f8 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<void>*, void*), boost::_bi::list2<boost::_bi::value<boost::function0<void>*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24
            28  AuUI                          0x036d6d22 aui::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 50
            29  com.adobe.dvacore.framework   0x0033caef void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 159
            30  com.adobe.dvacore.framework   0x0033f80c void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 92
            31  com.adobe.exo.framework       0x01b98adb -[ExoMacApplication handleMenuCommand:] + 235
            32  com.apple.AppKit              0x9767ae8f -[NSApplication sendAction:to:from:] + 112
            33  com.apple.AppKit              0x97729b64 -[NSMenu performActionForItemAtIndex:] + 493
            34  com.adobe.dvaui.framework     0x008e1f4a -[DVAMacMenu performActionForItemAtIndex:] + 58
            35  com.apple.AppKit              0x97729869 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 220
            36  com.apple.AppKit              0x977064ba AppKitMenuEventHandler + 6608
            37  com.apple.HIToolbox           0x911a413d DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
            38  com.apple.HIToolbox           0x911a357b SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
            39  com.apple.HIToolbox           0x911bfecc SendEventToEventTarget + 52
            40  com.apple.HIToolbox           0x911f41e7 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411
            41  com.apple.HIToolbox           0x9121a959 SendMenuCommandWithContextAndModifiers + 59
            42  com.apple.HIToolbox           0x9121a914 SendMenuItemSelectedEvent + 134
            43  com.apple.HIToolbox           0x9121a82a FinishMenuSelection(MenuData*, MenuData*, MenuResult*, MenuResult*, unsigned long, unsigned long, unsigned long, unsigned char) + 162
            44  com.apple.HIToolbox           0x911f7494 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 640
            45  com.apple.HIToolbox           0x911f6e7f _HandleMenuSelection2 + 383
            46  com.apple.HIToolbox           0x911f6cf3 _HandleMenuSelection + 53
            47  com.apple.AppKit              0x97642e67 _NSHandleCarbonMenuEvent + 244
            48  com.apple.AppKit              0x975a9bc2 _DPSNextEvent + 1918
            49  com.apple.AppKit              0x975a8f88 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
            50  com.apple.AppKit              0x975a1f9f -[NSApplication run] + 795
            51  com.adobe.exo.framework       0x01b97c87 exo::app::OS_AppBase::RunEventLoop() + 71
            52  AuUI                          0x036dc460 AudMacMain(int, char**) + 608
            53  com.adobe.Audition.4.0        0x00002ecd main + 93
            54  com.adobe.Audition.4.0        0x00002c66 start + 54
            Thread 1:
            0   libSystem.B.dylib             0x950359c6 kevent + 10
            1   libSystem.B.dylib             0x95036155 _pthread_start + 321
            2   libSystem.B.dylib             0x95036012 thread_start + 34
            Thread 2:
            1   libSystem.B.dylib             0x95036dcd pthread_cond_wait$UNIX2003 + 73
            2   ...ple.CoreServices.CarbonCore 0x95743de3 TSWaitOnCondition + 126
            3   ...ple.CoreServices.CarbonCore 0x95722c36 TSWaitOnConditionTimedRelative + 202
            4   ...ple.CoreServices.CarbonCore 0x95743a60 MPWaitOnQueue + 208
            5   com.adobe.dvacore.framework   0x003b72fa dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
            6   com.adobe.dvacore.framework   0x003b318a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
            7   com.adobe.dvacore.framework   0x0033f519 boost::function0<void>::operator()() const + 41
            8   com.adobe.dvacore.framework   0x003afbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
            9   com.adobe.dvacore.framework   0x003b0af0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
            10  ...obe.boost_threads.framework 0x000686fd thread_proxy + 141
            11  libSystem.B.dylib             0x95036155 _pthread_start + 321
            12  libSystem.B.dylib             0x95036012 thread_start + 34
            Thread 3:
            Thread 4:
            0   libSystem.B.dylib             0x95005266 mach_msg_trap + 10
            1   libSystem.B.dylib             0x9500ca5c mach_msg + 72
            2   com.apple.CoreFoundation      0x95533e7e CFRunLoopRunSpecific + 1790
            3   com.apple.CoreFoundation      0x95534aa8 CFRunLoopRunInMode + 88
            4   com.apple.audio.CoreAudio     0x9157e5f8 HALRunLoop::OwnThread(void*) + 160
            5   com.apple.audio.CoreAudio     0x9157e480 CAPThread::Entry(CAPThread*) + 96
            6   libSystem.B.dylib             0x95036155 _pthread_start + 321
            7   libSystem.B.dylib             0x95036012 thread_start + 34
            Thread 5:
            Thread 6:
            Thread 7:
            Thread 8:
            Thread 9:
            2   com.adobe.aubackend.framework 0x022b4a32 abe::afs::AudioFileSystem::CacheServices() + 322
            3   com.adobe.dvacore.framework   0x0033f519 boost::function0<void>::operator()() const + 41
            4   com.adobe.dvacore.framework   0x003b738a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 298
            5   com.adobe.dvacore.framework   0x003b318a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
            6   com.adobe.dvacore.framework   0x0033f519 boost::function0<void>::operator()() const + 41
            7   com.adobe.dvacore.framework   0x003afbfd dvacore::threads::(anonymous namespace)::LaunchThread(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
            8   com.adobe.dvacore.framework   0x003b0af0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
            9   ...obe.boost_threads.framework 0x000686fd thread_proxy + 141
            10  libSystem.B.dylib             0x95036155 _pthread_start + 321
            11  libSystem.B.dylib             0x95036012 thread_start + 34
            Thread 10:
            Thread 11:
            Thread 12:
            Thread 13:
            Thread 14:
            Thread 15:
            2   com.adobe.aubackend.framework 0x025029f0 abe::spectral::SpectralDataManager::Process() + 720
            Thread 16:
            0   libSystem.B.dylib             0x950052c6 semaphore_timedwait_signal_trap + 10
            1   libSystem.B.dylib             0x950372af _pthread_cond_wait + 1244
            2   libSystem.B.dylib             0x95038b33 pthread_cond_timedwait_relative_np + 47
            3   ...ple.CoreServices.CarbonCore 0x95722c62 TSWaitOnConditionTimedRelative + 246
            Thread 17 Crashed:
            0   ???                           0xc0000003 0 + 3221225475
            1   com.apple.audio.CoreAudio     0x91590177 HP_IOProc::Call(AudioTimeStamp const&, AudioTimeStamp const&, AudioBufferList const*, AudioTimeStamp const&, AudioBufferList*) + 319
            2   com.apple.audio.CoreAudio     0x9158fe68 IOA_Device::CallIOProcs(AudioTimeStamp const&, AudioTimeStamp const&, AudioTimeStamp const&) + 274
            3   com.apple.audio.CoreAudio     0x9158fd44 HP_IOThread::PerformIO(AudioTimeStamp const&) + 1246
            4   com.apple.audio.CoreAudio     0x9158e11f HP_IOThread::WorkLoop() + 1239
            5   com.apple.audio.CoreAudio     0x9158dc43 HP_IOThread::ThreadEntry(HP_IOThread*) + 17
            6   com.apple.audio.CoreAudio     0x9157e480 CAPThread::Entry(CAPThread*) + 96
            7   libSystem.B.dylib             0x95036155 _pthread_start + 321
            8   libSystem.B.dylib             0x95036012 thread_start + 34
            Thread 18:
            Thread 19:
            Thread 20:
            Thread 21:
            Thread 22:
            1   ...adobe.auscripting.framework 0x03379ea1 ScObjects::Thread::sleep(unsigned int) + 65
            2   ...adobe.auscripting.framework 0x03362483 ScObjects::BridgeTalkThread::run() + 179
            3   ...adobe.auscripting.framework 0x03379fce ScObjects::Thread::go(void*) + 174
            4   libSystem.B.dylib             0x95036155 _pthread_start + 321
            5   libSystem.B.dylib             0x95036012 thread_start + 34
            Thread 23:
            2   libGLProgrammability.dylib    0x90a9cb32 glvmDoWork + 162
            3   libSystem.B.dylib             0x95036155 _pthread_start + 321
            4   libSystem.B.dylib             0x95036012 thread_start + 34
            Thread 17 crashed with X86 Thread State (32-bit):
              eax: 0xb0847ec0  ebx: 0x1a742894  ecx: 0x0000010b  edx: 0xc0000003
              edi: 0x1acaa720  esi: 0x1acab390  ebp: 0xb0847b88  esp: 0xb084793c
               ss: 0x0000001f  efl: 0x00010286  eip: 0xc0000003   cs: 0x00000017
               ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
              cr2: 0xc0000003
            Binary Images:
                0x1000 -     0x2ff7 +com.adobe.Audition.4.0 4.0x10 (4.0) <1987e7d46a624ad70cc057aafbf937c0> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/MacOS/Adobe Audition
                0xa000 -     0xeffc +com.adobe.AdobeCrashReporter 2.5 (3.0.20090403) /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReport er
               0x14000 -    0x15ffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.227407) <b5f6001addb928d0200c784cea3867a1> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
               0x27000 -    0x43fd7 +com.adobe.LogTransport 1.0 (1.0) /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
               0x4e000 -    0x54fef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.227407) <43fff5ddeb22ba79ada7ce764691a3fa> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
               0x66000 -    0x6dff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.227407) <a4543c73757687a80f82eda4399aa816> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
               0x7d000 -    0x87ffd +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.227407) <008d30f21fa52cb647d4b681c4271647> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
               0x9f000 -    0xa2ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <ffddab7a220f7344f12b010ca0c41dab> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
              0x180000 -   0x184ff3 +com.adobe.dvaflashview.framework dvaflashview version 5.0.0 (5.0.0.227407) <93cdd4aa187d5c061ba3ea414516018b> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
              0x30b000 -   0x498fef +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.227407) <1a2036d523ca97dd1cc9197ca598b90a> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
              0x616000 -   0x978fff +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.227407) <4ccef8a1aef9a025e1270a8b053e76be> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
              0xd1b000 -  0x1098ff3 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.227407) <c2ca6aaf79fb41dcecf29b5d05789e11> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
            0x1607000 -  0x16b4fff +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0 (5.0.0.227407) <35f0d2ff1aa9b4eb7c8686b3aa51a24c> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
            0x1787000 -  0x17a9ff7 +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0 (5.0.0.227407) <b9489eb16251c8fa5abeb1d2835371f0> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
            0x17ca000 -  0x1829fff +com.adobe.dvametadata.framework dvametadata version 5.0.0 (5.0.0.227407) <706687d199b2d6a66d776e61f9204ab6> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
            0x18b2000 -  0x190aff7 +AdobeXMP ??? (???) <fc80e7a2d150d5a89aee879b05153a34> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
            0x1919000 -  0x19bfff3 +AdobeXMPFiles ??? (???) <cb814673a68c01e284a9500fa0d0e902> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
            0x19fb000 -  0x1a8dfff +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0 (5.0.0.227407) <8242b12a1da300979d673914f3525a8e> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
            0x1b26000 -  0x1b6ffff +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0 (5.0.0.227407) <89dd2c457b7763be08abc65f62d8bb16> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
            0x1b90000 -  0x1c3afff +com.adobe.exo.framework exo version 5.0.0 (5.0.0.227407) <3afc9275fc8a12ba9dee12e06a84346f> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/exo.framework/Versions/A/exo
            0x1d34000 -  0x1d52ff3 +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0 (5.0.0.227407) <cefb69c22b6f48031e762a7c27db7365> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
            0x1d7c000 -  0x1d87fff +com.adobe.aucore.framework 1.0 (1.0) <5138c72ad70915c9c7cf2dfb0bb63557> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
            0x1d94000 -  0x1f6bff2 +com.adobe.audsp.framework 1.0 (1.0) <1d00c1bb22390682a7d47c0eb91d746f> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
            0x1ffc000 -  0x2131fef +com.adobe.auaudiocomponents.framework 1.0 (1.0) <cad732eed001d483b0b0ddab3cb7632e> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AuAudioComponents.framework/Versions/A/AuAudioComponents
            0x2229000 -  0x259dff7 +com.adobe.aubackend.framework 1.0 (1.0) <839c916a0b0135cb481d1a11b58a2708> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBackEnd
            0x28af000 -  0x28b6fff +com.adobe.dvaundo.framework dvaundo version 5.0.0 (5.0.0.227407) <c879499b14be2a58e3a916a22bcb8599> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
            0x28c2000 -  0x2bf3fef +AuApplication ??? (???) <b85693ec7b9b8ff28224a867fdade88a> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AuApplication.framework/Versions/A/AuApplication
            0x2ec2000 -  0x2fa5feb +com.adobe.auuitoolkit.framework 1.0 (1.0) <11fc973340404df97bad2aaf1c698681> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuUIToolkit
            0x30ed000 -  0x3185ffb +AdobeExtendScript ??? (???) <46913918dc81801b64ca20859142b7cd> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
            0x31e4000 -  0x326aff7 +com.adobe.AdobeScCore ScCore 4.0.5 (4.0.5.3233) <c43541af83a7e11d50fb1ec7d6120ae9> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
            0x32ab000 -  0x33bcffb +com.adobe.auscripting.framework 1.0 (1.0) <9f05f5c5d1da4c5fe8caef6062622853> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuScripting
            0x3545000 -  0x35b4fff +com.adobe.auaudiocomponentsui.framework 1.0 (1.0) <fb33d5f05dd9cd3d4fdb97354b9b1c97> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versions/A/AuAudioComponen tsUI
            0x3652000 -  0x3fcdfef +AuUI ??? (???) <2a0283cad85fb9078c85f1a53e4c902d> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
            0x48e4000 -  0x4923fff  com.apple.vmutils 4.1 (104) <4f9d4dc239d5124d6a39d5395cbfaccc> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
            0x4945000 -  0x494fff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.227407) <c782506aeb8b535f9faadd68c619dc75> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
            0x4963000 -  0x49e0fe2 +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.227407) <f3cc925c22446042fa7d27b548cd668a> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
            0x4a45000 -  0x4b19fef +com.adobe.dvaeve.framework dvaeve version 5.0.0 (5.0.0.227407) <dbd4a2d42153724edb7ae7cef3f4298e> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
            0x4c13000 -  0x4c32fed  com.apple.audio.CoreAudioKit 1.5 (1.5) <795c36d256c2cead9607068b1f78e141> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
            0x4c44000 -  0x4d2cccb +iZBase ??? (???) <773f066f8fbe4947ba51d3a1bc62d2e1> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/iZBase.framework/Versions/A/iZBase
            0x4da9000 -  0x4e0de48 +iZDSPBase ??? (???) <c1575f2ece4643ad8f48d15b7097f082> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/iZDSPBase.framework/Versions/A/iZDSPBase
            0x4e26000 -  0x4ebc3a6 +iZotope_Radius ??? (???) <b6af5a0a6cfd429884509fd830471654> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZotope_Radius
            0x4ef9000 -  0x4f4fffb +com.adobe.headlights.LogSessionFramework ??? (2.1.0.1075) <abe97aafc5a9c72963d973ffb791bde2> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
            0x4f98000 -  0x5226fec +libxerces-c-3.0.dylib ??? (???) <cde6ff466d9a55b97df8ceb48ebb54b9> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
            0x53a9000 -  0x53d6ffb  libcurl.4.dylib ??? (???) <e70ed3c4c3a9ab52cca43930b038b2b8> /usr/lib/libcurl.4.dylib
            0x53e1000 -  0x5504ff7 +AdobeACE ??? (???) <6b4856dc3d41cef7cb70d02eea97b8d2> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
            0x5527000 -  0x5c01ff3 +AdobeAGM ??? (???) <fe943b4ded58f7538ae854e753a773bd> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
            0x5cc6000 -  0x5ce3ff7 +AdobeBIB ??? (???) <6cc35acf5ccd1509b4bb3b48ad140526> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
            0x5cea000 -  0x5d10ffb +AdobeBIBUtils ??? (???) <b9888beea93950e31cd33313ac14a073> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
            0x5d17000 -  0x6046ff3 +com.adobe.CoolType AdobeCoolType 5.10.7.10201 (5.10.7.10201) <6810a678b1dff96d256025ae3fda923a> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
            0x6098000 -  0x6105ffb +com.adobe.amtlib amtlib 3.5.0.34 (3.5.0.34) <8c1ebc9eddff660b03fb196ce8a4ced8> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
            0x17ef3000 - 0x181ecff3  com.apple.RawCamera.bundle 2.3.0 (505) <1c7cea30ffe2b4de98ced6518df1e54b> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
            0x1a3bf000 - 0x1a3f2fe3 +com.adobe.pip ??? (5.5.0.0) <6fcbb4c57eef1af802c638e429e66ea9> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
            0x1a3fd000 - 0x1a419ff7  GLRendererFloat ??? (???) <927b7d5ce6a7c21fdc761f6f29cdf4ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
            0x1a550000 - 0x1a551ffd +com.vmware.FusionVMDKPlugIn ??? (204229) /Library/Contextual Menu Items/FusionVMDKPlugIn.plugin/Contents/MacOS/FusionVMDKPlugIn
            0x1a555000 - 0x1a557ffe  com.apple.AutomatorCMM 1.1 (162) <413d7e87f90ba14adf2c2a08af448666> /System/Library/Contextual Menu Items/AutomatorCMM.plugin/Contents/MacOS/AutomatorCMM
            0x1a55d000 - 0x1a55effd  com.apple.BluetoothMenu 2.1.8 (2.1.8f2) /System/Library/Contextual Menu Items/BluetoothContextualMenu.plugin/Contents/MacOS/BluetoothContextualMenu
            0x1a666000 - 0x1a68ffeb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <e0f7666b921dc4d663b3e8b445d26892> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
            0x1a70b000 - 0x1a70efff  com.apple.audio.AudioIPCPlugIn 1.0.6 (1.0.6) <51c811377017028f8904ad779e6a1344> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
            0x1a714000 - 0x1a71afff  com.apple.audio.AppleHDAHALPlugIn 1.7.1 (1.7.1a2) <a0a4389b5ac52ab84397d2b25c9d3b9c> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
            0x1a720000 - 0x1a748fff +com.joesoft.hal ??? (1.0.3.344) /Library/Audio/Plug-Ins/HAL/Hear.plugin/Contents/MacOS/Hear
            0x1abe9000 - 0x1abeafe1  com.apple.textencoding.unicode 2.2 (2.2) <6566f38ef8ee61fab9aaecfb6a81f208> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
            0x1e209000 - 0x1e20aff3  ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
            0x1e25d000 - 0x1e2cdfeb +com.adobe.adobe_caps adobe_caps 3.5.4.0 (3.5.4.0) <36d53a2c0dab34c648c749d2ecf52d0d> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
            0x1e4df000 - 0x1e4e1fff  com.apple.BezelServicesFW 1.4.9212 (1.4.9212) /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
            0x1ee35000 - 0x1ee42fe7 +com.getdropbox.finderplugin ??? (169) <dc86a4751c477285d1dc52a50d0321a7> /Users/chrisreed/Library/Contextual Menu Items/DropboxPlugin.plugin/Contents/MacOS/DropboxPlugin
            0x1f931000 - 0x1f998fe7 +com.adobe.amt.services AMTServices 3.5.0.34 (BuildVersion: 3.5; BuildDate: Tue Sep 14 2010 21:49:00) (3.5.0.34) <f56d7855b0f74e7e1997d4fc2f5acb2d> /Users/chrisreed/Desktop/Adobe Audition.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
            0x1f9b4000 - 0x1f9b9fff  com.apple.FolderActionsMenu 1.3.2 (1.3.2) <d7aa79798607f865bd48718e2acd6e2b> /System/Library/Contextual Menu Items/FolderActionsMenu.plugin/Contents/MacOS/FolderActionsMenu
            0x1f9c0000 - 0x1f9c1ffc +com.yousendit.YSIFinderPlugin ??? (1.2) <c7ef2cf1da399e5c5aa2861f40904e42> /Library/Contextual Menu Items/YSIFinderPlugin.plugin/Contents/MacOS/YSIFinderPlugin
            0x1fb00000 - 0x1fc85fe3  GLEngine ??? (???) <3bd4729832411ff31de5bb9d97e3718d> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
            0x1fcb3000 - 0x1ff91ff1  com.apple.ATIRadeonX2000GLDriver 1.5.48 (5.4.8) <0858896931bc8cdd84f736ed21e23738> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLD river
            0x211a3000 - 0x21218ff7  com.apple.Bluetooth 2.1.9 (2.1.9f10) <d70a88066ebf7eb8071781f686caced3> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
            0x8fe00000 - 0x8fe2db43  dyld 97.1 (???) <458eed38a009e5658a79579e7bc26603> /usr/lib/dyld
            0x90006000 - 0x90006fff  com.apple.Carbon 136 (136) <ec1d4184925e652dbe1b9200a5a552ec> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
            0x90007000 - 0x9000efe9  libgcc_s.1.dylib ??? (???) <28a7cbc3a5ca2982d124668306f422d9> /usr/lib/libgcc_s.1.dylib
            0x90039000 - 0x9003efff  com.apple.CommonPanels 1.2.4 (85) <3b64ef0de184d09c6f99a1a7e77e42be> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
            0x9003f000 - 0x90088fef  com.apple.Metadata 10.5.8 (398.26) <e4d268ea45379200f03cdc7c8bedae6f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
            0x900d8000 - 0x90354fe7  com.apple.Foundation 6.5.9 (677.26) <c68b3cff7864959becfc7fd1a384f925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            0x90355000 - 0x903d2fef  libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
            0x903d3000 - 0x903d5ff5  libRadiance.dylib ??? (???) <97ff039f6d372ab58a684a0e311e4ed4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
            0x903d6000 - 0x904b7ff7  libxml2.2.dylib ??? (???) <b3bc0b280c36aa17ac477b4da56cd038> /usr/lib/libxml2.2.dylib
            0x904b8000 - 0x904d4ff3  libPng.dylib ??? (???) <d37524fe884aa164ab7db93d4c803b64> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
            0x904d5000 - 0x90587ffb  libcrypto.0.9.7.dylib ??? (???) <d02f7e5b8a68813bb7a77f5edb34ff9d> /usr/lib/libcrypto.0.9.7.dylib
            0x90588000 - 0x90594ffe  libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
            0x905c8000 - 0x906b0ff3  com.apple.CoreData 100.2 (186.2) <44df326fea0236718f5ed64084e82270> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
            0x906b1000 - 0x906b1ffa  com.apple.CoreServices 32 (32) <2760719f7a81e8c2bdfd15b0939abc29> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
            0x906b2000 - 0x906c7ffb  com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
            0x90895000 - 0x908f2ffb  libstdc++.6.dylib ??? (???) <6106b1f2b0b303b06ae476253dbb5f3f> /usr/lib/libstdc++.6.dylib
            0x90900000 - 0x9092dfeb  libvDSP.dylib ??? (???) <b232c018ddd040ec4e2c2af632dd497f> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
            0x9092e000 - 0x90970fef  com.apple.NavigationServices 3.5.2 (163) <91844980804067b07a0b6124310d3f31> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
            0x90a16000 - 0x90a1afff  libGIF.dylib ??? (???) <0984073a08c59c7c6be81e52cebf2bec> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
            0x90a50000 - 0x90a66fff  com.apple.DictionaryServices 1.0.0 (1.0.0) <7e9ff586b5c9d02b09e2a5527d98524f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
            0x90a67000 - 0x90a74fe7  com.apple.opengl 1.5.10 (1.5.10) <5a2813f80c9441170cc1ab8a3dac5038> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
            0x90a75000 - 0x90f46fbe  libGLProgrammability.dylib ??? (???) <7f18294a7bd0b6afe4319f29187fc70d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
            0x90f47000 - 0x90f49fff  com.apple.securityhi 3.0 (30817) <020419ad33b8638b174e1a472728a894> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
            0x90f64000 - 0x90f64ff8  com.apple.Cocoa 6.5 (???) <e9318c93615b27231498bbe585b8da98> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
            0x90f65000 - 0x90fbeff7  libGLU.dylib ??? (???) <a3b9be30100a25a6cd3ad109892f52b7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
            0x90ffc000 - 0x910acfff  edu.mit.Kerberos 6.0.14 (6.0.14) <673f107cdae80c084774a27bc7bc46c1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
            0x9119c000 - 0x914a4fe7  com.apple.HIToolbox 1.5.6 (???) <eece3cb8aa0a4e6843fcc1500aca61c5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            0x914f1000 - 0x914f1ffd  com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
            0x914f2000 - 0x914f9ffe  libbsm.dylib ??? (???) <5582985a86ea36504cca
            • 3. Re: Crashing with USB input device
              Thanks, Chris.  The thread that crashed, #17, shows the following:
              Thread 17 Crashed:
              It looks like the crash is occuring in Apple's CoreAudio library.  The first thing I'd recommend is to launch Audition with cleared preferences.  The simplest method is to launch Audition and hold down the SHIFT key until it's finished launching.  This will override the preferences and allow you to see if this made a difference.
              If you still crash, I would recommend temporarily changing the active device under Preferences > Audio Hardware  to Built-in Output/Input or one of the other options.  Verify that the crashing behavior does or doesn't also happen with this device, then change it back to your Alesis device.
              If you are still experiencing issues, we can continue troubleshooting.  I'm not sure if we have this specific USB audio device in our testing lab, but I'll inquire and see if this is an issue we can reproduce.
              Thanks.
              • 4. Re: Crashing with USB input device
                Charles VW Adobe Employee
                Looking at the audio device stuff:
                ChrisNH wrote:
                0x1a70b000 - 0x1a70efff  com.apple.audio.AudioIPCPlugIn 1.0.6 (1.0.6) <51c811377017028f8904ad779e6a1344> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
                0x1a714000 - 0x1a71afff  com.apple.audio.AppleHDAHALPlugIn 1.7.1 (1.7.1a2) <a0a4389b5ac52ab84397d2b25c9d3b9c> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
                Do you know what the com.joesoft.hal thing is?  Just searching around, and I'm wondering if it is the same problem as this one.
                • 5. Re: Crashing with USB input device
                  ChrisReed Level 1
                  Joesoft Hear was doing it.  It's a plugin for iTunes that I had tried a while back and ultimately abandoned; apparently it was still running in the background.  Not sure how to explain why it wasn't running when I first launched Audition (since I didn't have any issues the first time around), but now that I've removed it, Audition works fine every time.
                  Thanks to both of you, and especially Charles.  Much appreciated.
