4 Replies Latest reply on Nov 16, 2010 3:30 PM by davidbeisner2010
    Removing hum from audio
    UpstateVideo
      Lost the audio tracks from the mixer, so
      all I have is the audio from the RED camera.  There is a constant hum.
      I tried the DeHummer tool at different settings, no luck.
      All I have is Premiere CS5, no other tools like Audition.  Is there a way to remove the hum
      since it is constant?  The audio files are *.mov for some reason, so Audacity didn't help either.  Of all the scenes that could get screwed up, its the one with my five year old in it!  UGH!!!!!
      Thanks for your time,
      Stuart
        • 1. Re: Removing hum from audio
          the_wine_snob Level 9
          Stuart,
          Much will depend on the frequency range of the hum and on the frequency range of the Audio that you wish to preserve. This ARTICLE will give you some tips.
          While I use Audition, SoundBooth (do you have that program, as it's included in most Adobe suites?) should be able to help, as can the great, little free Audacity.
          • 2. Re: Removing hum from audio
            Jim_Simon Level 8
            You used a RED for home video?!?!  (I'm soooo jealous.)
            I've never used the MOV proxies from a RED, so I can't say their qualities will be any different, but have you tried the native R3D files at all?  Do they exhibit the same hum?
            • 3. Re: Removing hum from audio
              Bill_Wood
              Stuart - Just about any version of Sony's Sound Forge Pro has an excellent filter that can be used to remove or greatly reduce unwanted hum from audio tracks.  It has up to four cascaded notch filters that can be adjusted for frequency and bandwidth.  I have one filter set to remove 60, 120, and 180 Hz hum from sound tracks.  - Bill
              • 4. Re: Removing hum from audio
                davidbeisner2010 Level 3
                Open it up in Premiere and export the audio tracks as waveforms, bring them into Audacity (actually, you might try AIFFs... I've had trouble with Premiere wav output crashing Audacity) and do your noise removal there. It's tools are far superior to those built into Premiere, and I've had very little success with SoundBooth, either.
