3 Replies Latest reply on Nov 15, 2010 6:09 AM by kglad
    xml driven swf banner rotator
    resolution revolution
      Please help.
      I have a banner rotator / slideshow with 30 swf's. I have an xml file driving the slideshow. My problem is that I have video pop-ups in each of the 30 linked swf's and a geturl in each of the swf's. I need to be able to drive this content from the xml file. Is that possible? to read an xml file from a linked swf?
      Root file AS:
      function desc_change(id)
          if (item_array[id].desc != undefined && item_array[id].desc != "")
              description.desc.htmlText = item_array[id].desc;
          // end if
      }// End of the function
      _global.vidTitle;
      _global.vidUrl;
      _global.learnUrl;
      function init()
          _global.item_array = mx.xpath.XPathAPI.selectNodeList(feed_xml.firstChild, "/list/item");
          _global.interval = feed_xml.firstChild.attributes.interval;
          _global.startup_slideshow = feed_xml.firstChild.attributes.startup_slideshow;
          for (i = 0; i < item_array.length; i++)
              item_array[i].pic = item_array[i].childNodes[0].firstChild.nodeValue;
              item_array[i].thumb = item_array[i].childNodes[1].firstChild.nodeValue;
              item_array[i].title = item_array[i].childNodes[2].firstChild.nodeValue;
              item_array[i].videotitle = item_array[i].childNodes[3].firstChild.nodeValue;
              item_array[i].videourl = item_array[i].childNodes[4].firstChild.nodeValue;
              item_array[i].learnurl = item_array[i].childNodes[5].firstChild.nodeValue;
              item_array[i].desc = item_array[i].childNodes[6].firstChild.nodeValue;
              item_array[i].id = i;
          }// end of for
          p = 0;
              it = items_mc.item.duplicateMovieClip("item" + i, i);
              it.pic.loadMovie(item_array[i].thumb);
              it.txt.text = item_array[i].title;
              it.txt2.text = item_array[i].title;
              it.id = item_array[i].id;
              vidTitle = item_array[0].videotitle;
              vidUrl = item_array[0].videourl;
              learnUrl = item_array[0].learnurl;
              it.bg.onRollOver = function()
                  if (!this._parent._parent._parent.moving)
                      this.gotoAndStop(2);
                  // end if
              it.bg.onRollOut = function()
                  this.gotoAndStop(1);
              it.bg.onRelease = function()
                  vidTitle = item_array[this._parent.id].videotitle;
                  vidUrl = item_array[this._parent.id].videourl;
                  learnUrl = item_array[this._parent.id].learnurl;
                  //trace(vidTitle);
                  //trace(vidUrl);
                  //trace(learnUrl);
                  if (!this._parent._parent._parent.moving && this._parent.id != this._parent._parent._parent.cur_img_id)
                      this._parent._parent._parent.big_load(this._parent.id);
                  // end if
              if (i % 3 == 0)
                  it._x = p;
              else
                  it._x = p;
              }// end else if
              p = it._x + 275;
          }// end of for
          if (startup_thumbs_hide == "Yes")
              items_mc._alpha = 0;
              items_mc._y = 220;
              items_mc._visible = 0;
          else
              thb_bg._show = true;
              thb_bg.gotoAndStop("show_startup");
              caption._visible = 0;
          }// end else if
          big_load(0);
          if (startup_slideshow == "No")
              clearInterval(timer_update_id);
              timer.ico.gotoAndStop(2);
              timer._show = true;
          // end if
      function create_blur(flg)
          for (index in items_mc)
              if (flg)
                  items_mc[index].filters = [new flash.filters.BlurFilter(25, 0, 1)];
                  continue;
              // end if
              items_mc[index].filters = [null];
          }// end of for...in
      function move_right()
          if (items_mc._x <= -246.51 * item_array.length)
              trace(items_mc._width);
          else
              trace(items_mc._x);
              moving = true;
              create_blur(1);
              items_mc.onEnterFrame = function()
                  if (this._x > -this._parent.page * 275)
                      this._x = this._x - 50;
                  else
                      this._x = -this._parent.page * 275 + 1;
                      delete this.onEnterFrame;
                      ++this._parent.page;
                      this._parent.create_blur(0);
                      this._parent.moving = false;
                      if (this._parent.page > Math.ceil(item_array.length / 3) - 1)
                          this._parent.right._visible = 1;
                      // end if
                      if (!showing)
                          ++cur_img_id;
                          if (cur_img_id > item_array.length - 1)
                              cur_img_id = 0;
                          // end if
                          big_load(cur_img_id);
                      // end if
                  }// end else if
      function move_left()
          if (items_mc._x == 1 || items_mc._x == 1.35)
          else
              trace(items_mc._x);
              moving = true;
              create_blur(1);
                  if (this._x < -(this._parent.page - 2) * 275)
                      this._x = this._x + 50;
                  else
                      this._x = -(this._parent.page - 2) * 275 + 1;
                      --this._parent.page;
                      if (!showing)
                          --cur_img_id;
                          if (cur_img_id < 0)
                              cur_img_id = item_array.length - 1;
                          // end if
                      // end if
                  }// end else if
      function big_load(id)
          if (!showing)
              cur_img_id = id;
              moving = true;
              showing = true;
              image.id = id;
              image.gotoAndPlay("hide");
              desc_change(id);
          // end if
      var feed_xml = new XML();
      feed_xml.ignoreWhite = true;
      feed_xml.load("data.xml");
      feed_xml.onLoad = function(success)
          init();
      items_mc.setMask(mask1);
      page = 1;
      setInterval(caption_tracking,10);
      big_preloader._alpha = 0;
      var big_Listener = new Object();
      var big_mcl = new MovieClipLoader();
      big_mcl.addListener(big_Listener);
      big_Listener.onLoadProgress = function(target_mc, loadedBytes, totalBytes)
          big_preloader._alpha = 100;
          big_preloader._xscale = Math.floor(loadedBytes / totalBytes * 100);
      big_Listener.onLoadInit = function(target_mc)
          image.gotoAndPlay("show");
          big_preloader.onEnterFrame = function()
              if (this._alpha > 0)
                  this._alpha = this._alpha - 10;
              else
                  this._alpha = 0;
              }// end else if
      XML file:
      <list interval="10" startup_thumbs_hide="No" click_thumbs_hide="No" startup_slideshow="Yes">
          <item>
              <pic>banners/1.swf</pic>
              <thumb>thumbs/1.gif</thumb>
              <title>Green Airways</title>
              <videotitle>Green Airways</videotitle>
              <videourl>http://honeywell.feedroom.com/?skin=oneclip&fr_story=f9719091cc3ee7a2f3ffb834ca16c3c7c18fe fdb&rf=ev&autoplay=true</videourl>
              <learnurl>https://commerce.honeywell.com/webapp/wcs/stores/servlet/ECategoryDisplay?catalogId=10101& storeId=10651&categoryId=32429&langId=-1</learnurl>
              <description><![CDATA[<font face="Arial" size="11" color="#666666">1-3 of 30]]></description>
          </item>
      </list>
      Linked swf code for learnurl button:
      on (release) {
          var str = _parent._parent._parent.learlUrl;
          getURL(learnurl,"_blank");
      this last part is not working. Can anybody help? Thanks in advance, sorry I can't post the files.
