3 Replies Latest reply on Nov 15, 2010 10:39 PM by Yateam
    external type of linking. problems
    Yateam Level 1
      Hi all,
      I faced a problem linking a library to my project. There is main application A and module M. I added library X to the module externally. Then I added the same library to the main application merging it to the code. So, library X is included in module M as 'external' and in application A as 'merged in code'. No classes from X are used in the main application. Only module M used library X and its classes. All is compiled well but when I run the application it raises the error during loading the module: Main Thread (Suspended: VerifyError: Error #1014: Class 'class_definition' could not be found.). How should I compile the library to avoid such run time errors?
      Thanks.
