3 Replies Latest reply on Nov 15, 2010 7:27 AM by the_wine_snob
    dvd judder
    sevvie1 Level 1
      hi any one help,premiere 7/8 i have prodeced dvd's using the programme,with no problem,however i sometimes loose the project file from the origanal edit so copy the master dvd content to the programme and use this to reditthen recopy the dvd,however i cant get rid of the judder on panning,have tride upper and lower fied options with out any luck have tried all the options and loads of discs.any ideas rob
        • 1. Re: dvd judder
          nealeh Level 5
          Are you saying that the original didn't have the judder?
          As an aside, DVD is a highly compressed format. So if you are loading from your DVD into PRE, editing and and then writing out to a fresh DVD quality will suffer. This is because PRE re-compresses footage that has already been compressed once. But I don't think this would introduce judder where there was none before.
          Cheers,
          Neale
          • 2. Re: dvd judder
            What type of camcorder is your original footage coming from and which project settings did you select when you started your Premiere Elements project?
            • 3. Re: dvd judder
              the_wine_snob Level 9
              I think that Neale has isolated the problem - multiple MPEG-2 compression, but if all you want to do is just make a Copy of the existing DVD, I recommend a great, free burning utility, ImgBurn, that will just make a Copy of your DVD to another blank disc. This process will eliminate one MPEG-2 compression, and yield the highest possible quality - identical to that original DVD.
              As a tip, for best playability, use only high-quality blank discs, like Verbatim, or Taiyo Yuden, and burn at less than max speed. ImgBurn, unlike the burning capabilities in PrE, will allow you to adjust the burn speed.
